TurboSmart vs Tial wastegates
Does anyone have a preference over another?
I've never heard bad things about either, but the TurboSmart is shorter, and more compact, making it the better choice for me.
So, before I buy one: TurboSmart ot Tial?
Ive used both and both have awesome quality. I personaly use a Turbosmart 48mm on my car and love it. I saw fast-turbo.com has a special on the 38mm wg in the sponsor's market.
art
art
I like the turbosmart ones better because they come with a leaded gas valve which is a good thing if you ever run race gas. Plus they even come with different springs rates which is awsome because it will save you money in case you need to change combinations or need more boost
check it out our monthly special: https://honda-tech.com/zerothread?id=1300075
heres my personal 48mm turbosmart that I plan on using (and the one Arturbo currently uses)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01geeser »</TD></TR><TR><TD CLASS="quote">how much for the 48mm?</TD></TR></TABLE>
$465.00 in the sponsors forum.
wouldnt a different spring affect the rate at which the turbo spools up because spring pressure has changed? A 14lb spring may hit boost faster then a 8lb spring set at 14lbs. Just curious.
The turbo is not going to spool up faster with a larger spring compared to a lower spring that is compressed. They will both open at the same pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civicsi »</TD></TR><TR><TD CLASS="quote">is the flange on the turbosmart 48mm same as the tial 44mm</TD></TR></TABLE>
no considerably Different.
The turbosmart stuff is much bigger/bulkier
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by This One »</TD></TR><TR><TD CLASS="quote">
The turbosmart stuff is much bigger/bulkier</TD></TR></TABLE>
Damn if that is true that would suck.
im currently running a single 44mm which holds boost with zero problem.
365shipped http://www.kohlerperformance.com
Its really going to depend on manifold design. if the design wont allow the boost to hold, it wont.
underpressure02
Oct 20, 2004 07:31 AM
