Help! CRX not starting after moving battery to the back
OK I just finished moving the battery to the back. Now the starter isn't working. The acc's have power but when I hit the start position nothing happens.
Any clue?
Any clue?
The starter isn't getting enough current to drive the motor. So either you ran too thin power wire (need 4 guage or thicker), or you have a bad ground. You can check the impedance between an engine ground and your battery ground. It should be pretty low.
it may not be nessesary at this point to make measurements (with volt meter: Fluke). First try sanding down the ground location and make sure its on/rear the main frame rail and on a thick section of metal. Try to utilize a stock threaded bolt location to ensure good contact. Sand metal and apply a conductive gel like used on spark plugs if needed. This will increase conductivity and lower chances of corrosion at the contact.
dudee
Nov 23, 2010 07:34 AM
9 CRX si 1
Nov 5, 2006 03:36 PM
