Map Sensor CEL Please Help
I recently did an engine swap. I went from a usdm h22 to a jdm h22. The car ran fine after i swapped for a few days and than it started to lose power. It threw a CEL not long after. It threw code 3. I reset the ecu and the car ran fine for about 4 days and than the problem happened again with the same CEL. I checked in my helms and followed the flow chart. It had me measuring the voltage of all 3 of the wires coming out of the map sensor plug. 2 of the 3 combinations registerd around 5.05 v and the other one which was the white.blue wire as the positive + and the blue/white as the negative - i got a reading of 4.75. The helms states "Is there approx. 5 V? Is that my problem? Is my map sensor bad? Are the H22 and H23 map sensors the same? What should I do
The cel is still coming on. I have reset the ecu 3 times and it doesn't come on for about 3 days. The car hesitates bad before the cell comes on. Let me know still throwing the same code
mortificationrock
Aug 18, 2010 08:22 PM
