where is a good ground for second battery in rear of Integra?
Old Jul 5, 2005 | 09:05 AM
CrazyModGSR's Avatar
Default where is a good ground for second battery in rear of Integra?
I am in the final phases of finishing my stereo install, and wondering if anyone has experience with putting a second battery in the back of a DC2 Integra hatch, and where it was grounded. I see one decent stock bolt, but it is real big. Any suggestions on a good ground for a 1/0 ring terminal?
Old Jul 5, 2005 | 09:16 AM
nickG's Avatar
Default Re: where is a good ground for second battery in rear of Integra? (CrazyModGSR)
theres a square piece of metal in the rear and center of my car that my battery is grounded to.
but you can drill a hole, scrape some paint, and ground it anywhere...
Old Jul 5, 2005 | 09:48 AM
93_teg_CT's Avatar
Default Re: where is a good ground for second battery in rear of Integra? (nickG)
Is it necesary to have two batteries? Cause I have a 500w amp powering my speakers, and a 1000w powering my subs, all alpine type s stuff and I just run it off my stock battery and I haven't ran into any problems. I'm not trying to be sarcastic it was a real question I was wondering if I might have some problems down the line or something...
Old Jul 5, 2005 | 09:53 AM
Default Re: where is a good ground for second battery in rear of Integra? (93_teg_CT)
I have 2 mono amps (1200 watts RMS total), 2 channel at 150 watts RMS, 500 watt power inverter, 400 watt power inverter, carputer, 30 neon tubes, 2 underbody neons, whelen strobes, and yes it is all necessary, lol
I originally had an 11" comp sub along with the four 12's, but before the install I removed the 11" because I decided it would sound off with the other 12's (11" at 900 watts RMS, 12's at 300 watts RMS), so I removed it and put a 17" xbrite screen in it's place.
Old Jul 5, 2005 | 09:55 AM
Plinko's Avatar
i grounded mine by lifting up the carpet and trunk board and just found some randomn bolt and grounded it there. just make sure you have a long cord so you can hide most of it behind carpet and it wont get in way.
Old Jul 5, 2005 | 09:59 AM
93_teg_CT's Avatar
Holy batman pimp my ride style.
You put 2fast2furious to shame with that thing! lol
But something like my setup I wouldn't need 2 batteries...?
Old Jul 5, 2005 | 10:05 AM
yes, there is no rational purpose for 1/4 audio/video equipement in my car, I just got carried away. at least I am looking at upping my boost from 7 psi to hopefully over 20 psi after I have a lot of motorwork done this winter. my goal is 400-500 hp. who says you can't have 400 lbs of stereo equipment and be quick
Old Jul 7, 2005 | 09:48 AM
I wanted to double check, but this is NOT an acceptable ground right? I would want something more solid? I just hate to have to drill a 1/0 hole through the car, and then drill another hole to bolt to.
Old Jul 7, 2005 | 09:54 AM
91TegLS's Avatar
When I relocated my battery to the trunk, I used the very large bolt that holds the seat belt in. Works perfect and it's only about 3ft of ground cable at the most.
-Dave
Old Jul 7, 2005 | 11:40 AM
Default Re: where is a good ground for second battery in rear of Integra? (91TegLS)
is this the bolt you are talking about? do you think I should ground both the battery and ground d-block to that bolt, or should I ground the dist block to the bolt with the question mark? I have 3 amplifiers and a capacitor running to one block, and then I need to ground to one point, maybe the circle with the question mark.
Old Jul 7, 2005 | 11:43 AM
solareclipseauto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91TegLS &raquo;</TD></TR><TR><TD CLASS="quote">When I relocated my battery to the trunk, I used the very large bolt that holds the seat belt in. Works perfect and it's only about 3ft of ground cable at the most.
-Dave</TD></TR></TABLE>
delsolo95
Audio / Security / Video
Jan 26, 2012 09:36 AM
mrdeadman
Sep 29, 2005 09:13 PM
-TJ
Oct 18, 2003 10:50 PM
pwrdbydzntz
Sep 11, 2002 08:55 PM
