power question
Old Sep 29, 2005 | 01:47 PM
mrdeadman's Avatar
They let me pick
Default power question
it i wanted to install a second battery to power a second amp i would need to ground the neg end of the battery right? to the car chassis? can one battery power two amps? does it depend on the output of the amp?
Old Sep 29, 2005 | 01:52 PM
nsxxtreme's Avatar
Default Re: power question (mrdeadman)
Why do you want 2 batteries? Do you plan to sit somewhere for a long time with your car off?
Old Sep 29, 2005 | 01:55 PM
mrdeadman's Avatar
They let me pick
Default Re: power question (nsxxtreme)
i was wondering if i needed two. because the starter runs off of the same battery as the first amp and when both draw current at the same time it is hard to start (sometimes) therefore leading me to conclude that if i got a second amp i would need a second battery so as not to drain the first one as fast. is this a legit argument?
edit: then when the second battery ran out of juice, i would unhook it and pop it on a charger. or is this not worth it?
Old Sep 29, 2005 | 02:04 PM
nsxxtreme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote"> is this a legit argument?</TD></TR></TABLE>No, Your stereo should not work when the starter is engaged.
I doubt you need a second battery.
Old Sep 29, 2005 | 05:59 PM
mrdeadman's Avatar
They let me pick
so what youre saying is that when the starter is engaged the stereo shuts off or doesn't come on until after the car is started so that the stereo doesn't steal the current the battery needs to start the car? that's pretty ingenious. thanks for the help.
Old Sep 29, 2005 | 09:13 PM
nsxxtreme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">so what youre saying is that when the starter is engaged the stereo shuts off or doesn't come on until after the car is started so that the stereo doesn't steal the current the battery needs to start the car? that's pretty ingenious. thanks for the help. </TD></TR></TABLE>
yup
SD1222
Audio / Security / Video
May 11, 2006 06:45 PM
i
Nov 21, 2003 11:37 AM
ilikemyaccord
Jul 6, 2003 06:20 PM
RedDawg
15
Jul 3, 2001 08:41 PM
