Need Help... Oil Pump...Bent valves
Old Jul 4, 2005 | 08:45 PM
liitezout's Avatar
Default Need Help... Oil Pump...Bent valves
First off...thanks for reading this thread...
Tonight my Oil light came on out of nowhere..and the car started idling a little off....then it shut off by itself and would not really start again and hold a decent idle.
Im thinking that it could possibly be my oil pump that suddenly went out on me? and lost pressure? Because the oil light coming on out of nowhere is odd...my motor was not leaking oil and i had just changed the oil a week or so ago..
Thanks again and any advice or help would be great..
Old Jul 4, 2005 | 08:56 PM
Andres-eh2's Avatar
How many miles?
Old Jul 4, 2005 | 09:17 PM
Luserkid's Avatar
Default Re: (Andres-eh2)
More info man, thats very vague. If you would like depending on where in So. Cal your at i could trouble shoot for you but really this thread is to vague.
I dont see how you could have bent a valve though.
Old Jul 4, 2005 | 09:37 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: Need Help... Oil Pump...Bent valves (liitezout)
Oil light = loss of oil pressure. Put an oil pressure guage in where the oil pressure sending unit is and start the motor. If the guage reads 0psi stop the motor and repair the problem. Otherwise warm the vehicle up to operating temp (fan comes on at least twice) and check the pressure. Should be 10psi at idle minimum and 50psi at 3000 rpm minimum.. That simple.
Old Jul 5, 2005 | 11:12 AM
liitezout's Avatar
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">More info man, thats very vague. If you would like depending on where in So. Cal your at i could trouble shoot for you but really this thread is to vague.
I dont see how you could have bent a valve though. </TD></TR></TABLE>
the car made it home to my house..so iono i dont think i should of driven it home.
Old Jul 5, 2005 | 11:13 AM
liitezout's Avatar
i have a new oil pump on the way..ill keep posted..thanks guys
Old Jul 5, 2005 | 01:07 PM
philosofy1's Avatar
i had the same problem, oil light came on, car would shut off after driving, would keep a decent idle. took it to the shop and found out i had loss of compresion in one of my cylinders. you should have it checked out.
Old Jul 6, 2005 | 12:03 AM
liitezout's Avatar
Default Re: Need Help... Oil Pump...Bent valves (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem, oil light came on, car would shut off after driving, would keep a decent idle. took it to the shop and found out i had loss of compresion in one of my cylinders. you should have it checked out. </TD></TR></TABLE>
thanks for the info
lonewsome
Jan 1, 2009 01:42 PM
Takumi Fujiwara
Jul 22, 2006 04:13 PM
Supahr_Ed
May 27, 2006 11:51 AM
BACKintheDA
Jul 12, 2005 01:05 PM
LostCRX
Jun 21, 2005 07:12 PM
