check engine light
have a little problem : the check engines turns on at 180 km/h , but if i stop the car and start it again it dissapears
in the 4-th gear the vtec kicks in and out , but the car it's reving and accelerating
are this 2 problems related to each others ???
help
help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">please explain how vtec kicks in and out? check the codes and see what it is</TD></TR></TABLE>
And to check codes please check out this link...
https://honda-tech.com/zerothread?id=1171263
For the vtec problem, check the oil level and the vtec oil screen. There are other things to check, but I would start with these.
As for the other problem, I don't know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cioli »</TD></TR><TR><TD CLASS="quote">vtec oil screen ? please explain what's is that
today i will see wich code is </TD></TR></TABLE>
There is a screen that filters the oil enthering the vtec pressure switch and solenoid, if that screen gets clogged problems like your describing can occur.
LSegHatchy
Jun 6, 2005 08:04 PM
