Help with my jl audio system!!
Old Jul 3, 2005 | 03:48 PM
DirtyzGsR_9i6's Avatar
Default Help with my jl audio system!!
im runnin a jl 500/1 with a 12'' w7...after hooking it all up....it was working fine for a few minutes...then my sub turns off and on constantly...could it be the amp?...i think there is something wrong with the amp...its probably a shortage in the amp that makes it power the sub on and off....some1 help...lol
Old Jul 3, 2005 | 05:04 PM
fcm's Avatar
fcm
Old Fart
Default Re: Help with my jl audio system!! (DirtyzGsR_9i6)
You need to disconnect the sub and and check it with a multimeter or DVM, I would also check all the connections, take a close look at the amp ground, and check the fuse on the amp power wire, by the batt., make sure it's not defective. 94
Old Jul 4, 2005 | 11:56 PM
4runner's Avatar
Default Re: Help with my jl audio system!! (fcm)
you're clippin
what head unit you got?
its a power issue, i had a same problem when i ran a shitty kenwood to my 2 jl's..after i got an eclipse HU, everything was sweet
probably a power issue
Old Jul 5, 2005 | 12:16 AM
Default Re: Help with my jl audio system!! (88HaveFun)
i got a alpine cda-9533...its one of the top models from last year...its good stuff...
Old Jul 5, 2005 | 12:18 AM
the ground is hardest with integras....i had problems getting a good ground...i hooked it up to the spare tire....
Old Jul 5, 2005 | 07:35 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtyzGsR_9i6 &raquo;</TD></TR><TR><TD CLASS="quote">the ground is hardest with integras....i had problems getting a good ground...i hooked it up to the spare tire....</TD></TR></TABLE> What do you mean? "i hooked it up to the spare tire" also, where have you got the amp mounted? 94
Old Jul 5, 2005 | 10:39 AM
NC-B17A's Avatar
You need to keep the ground wire short & it has to be grounded to bare metal.
What ga. wire did you use?
Old Jul 5, 2005 | 10:44 AM
4runner's Avatar
Default Re: Help with my jl audio system!! (NC-B17A)
could be the ground, start scrappin some paint til you see bare metal
or just go check all the wirings again..
Old Jul 5, 2005 | 08:12 PM
SILVIC00's Avatar
not to thread jack or anything but i checked my power setup with a dvm and when i turn amp on i have only 5v at the amp and on the remote and no sound commin out of speakers
headunit: eclipse av5101
amps: jl 250/1, jl e4300
wiring: 4 gauge to 8 gauge dist block (both power and ground)all monster cable and rcas
anyone have any suggestions, any help would be appreciated..thanks
Old Jul 6, 2005 | 07:38 AM
fcm's Avatar
fcm
Old Fart
Default Re: Help with my jl audio system!! (SILVIC00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SILVIC00 &raquo;</TD></TR><TR><TD CLASS="quote">not to thread jack or anything but i checked my power setup with a dvm and when i turn amp on i have only 5v at the amp and on the remote and no sound commin out of speakers
</TD></TR></TABLE>Use a jumper, [piece of wire] jump from the amps 12V+ term. to the amps remote term. see what happens
Old Jul 9, 2005 | 01:31 PM
4 gauge amp kit...wid a 60 agu fuse...
Old Jul 9, 2005 | 02:45 PM
SILVIC00's Avatar
brainbox took a **** and was shorting out remote signal and rcas
Old Jul 9, 2005 | 03:57 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtyzGsR_9i6 &raquo;</TD></TR><TR><TD CLASS="quote">4 gauge amp kit...wid a 60 agu fuse...</TD></TR></TABLE> Replace the agu fuse, even if it looks good 94
NewtoCivics
Audio / Security / Video
12
Jan 11, 2012 04:28 AM
White Boy Hatch
18
Jan 4, 2011 10:05 PM
White Boy Hatch
Jan 4, 2011 08:19 AM
OneFire
Dec 10, 2008 12:30 PM
Ziggie
Aug 22, 2003 03:23 PM
