AC Problem -- Refrigerant wont leave the can and go into the car
Old Jul 3, 2005 | 12:29 PM
David W.'s Avatar
Default AC Problem -- Refrigerant wont leave the can and go into the car
I tried to recharge my AC system (96 civic, uses R-134) and I am having some issues. I connected the hose to the Low connection port, hooked up the can and released the freon. The freon wont leave the can, it just sits there. The can doesn't get cold really.... the top is definitly pierced, I have the car running and AC on blast but the freon wont leave the can and go into the car. I can shake the car profusly, nothing happens, turn it upside down, place it in a bucket of warm water, etc..... I am just wasting Freon trying to charge my car.
Does the car have to be level, front or rear pointing down? AC Compressor seems to work fine. I dont know what else it could be.
Modified by David W. at 2:07 PM 7/3/2005
Old Jul 3, 2005 | 12:33 PM
97civicdx's Avatar
Default Re: AC Problem -- Refrigerant wont leave the can and go into the car (David W.)
ur 96 car is r-134a, not r-12!!!!!!!!!!!
Old Jul 3, 2005 | 12:35 PM
moto1320's Avatar
Default Re: AC Problem -- Refrigerant wont leave the can and go into the car (97civicdx)
lol. ruh roh raggy. just get a shop to pull the whole thing down for you and get a good vacuum on it. It's not much at all for a evac and recharge with no repair involved.
Old Jul 3, 2005 | 12:58 PM
kkim's Avatar
are you using the recharge kit w/ a gauge inline? if so, what is it reading? if without, you have no way of knowing what the system pressure is.
when you press down on the low side valve, does pressure escape? perhaps you have a stuck valve? if not, then I would look at the hose end of the charger to make sure there is a pin which is suppose to push the valve open to let the refrigerant flow from the can into the system.
btw, turning the can upside down is not a good idea. you want the liquid inside the can to be in a gas state when entering the system ,which is why they say to shake the can when refilling.
good luck
p.s.- your system uses r134, not r12.
Old Jul 3, 2005 | 01:09 PM
David W.'s Avatar
my bad. I was thinking one thing and typed another. I am using 134. I do have a bunch of cans of R-12 still though. Pressure releases the system when I push the pin.
Old Jul 3, 2005 | 03:01 PM
kkim's Avatar
do you have a gauge to read pressure on the low side?
Old Jul 3, 2005 | 05:38 PM
egtwincam's Avatar
is your compressor clutch on? if not then thats why your its not sucking it in on hte low side. i would take it to a shop to get it done right. that way they can evacuate the system and suck out all the moisture,dirt, oil and recharge your system to operate at max potential.
Old Jul 3, 2005 | 05:52 PM
Turbogixxer's Avatar
Default Re: AC Problem -- Refrigerant wont leave the can and go into the car (kkim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kkim &raquo;</TD></TR><TR><TD CLASS="quote">do you have a gauge to read pressure on the low side?</TD></TR></TABLE>
You need to know your pressure to insure the system is working correctly. If you can get a high and low pressure guages, it you help you better.
Old Jul 4, 2005 | 09:13 AM
David W.'s Avatar
Default Re: AC Problem -- Refrigerant wont leave the can and go into the car (Turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
You need to know your pressure to insure the system is working correctly. If you can get a high and low pressure guages, it you help you better.</TD></TR></TABLE>
aight... I will go get one. Thanks guys
23LX23
Jul 17, 2010 10:30 AM
honda_ricer
Feb 6, 2010 05:03 PM
playahwitgame
Aug 10, 2006 01:54 PM
AW
Sep 2, 2005 08:53 AM
