Bent rim + inspection?
Old Jul 3, 2005 | 10:24 AM
tthomass's Avatar
Default Bent rim + inspection?
i've got Rota C8's on my 99SI............the LIP is bent on the driver's front, is that failure?
-also one tire is at/right at hte wear bars on just the outside due to be'n underinflated and the center is fine, failure?
thanks!
Old Jul 3, 2005 | 12:54 PM
tthomass's Avatar
Default Re: Bent rim + inspection? (Senses Fail y0!)
read the post before replying like a retard...........the LIP is whats damged, NOT the rim........the rim itself is perfectly round, just the very outside part of the lip has a flat spot
Old Jul 3, 2005 | 03:12 PM
Targa250R's Avatar
be professional
Default Re: Bent rim + inspection? (tthomass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tthomass &raquo;</TD></TR><TR><TD CLASS="quote">-also one tire is at/right at hte wear bars on just the outside due to be'n underinflated and the center is fine, failure?</TD></TR></TABLE>
If 2/32nds of tread is the limit, then yes, they can fail you. Doesn't matter if there is more tread on the rest of the tire.
Old Jul 3, 2005 | 10:44 PM
T4eg's Avatar
Default Re: Bent rim + inspection? (Targa250R)
a bent rim is a the inspector's call
Old Jul 4, 2005 | 02:21 AM
eXcelonTypeR's Avatar
Default Re: Bent rim + inspection? (T4eg)
i thought the lip holds part of the bead?? so if it's overly damaged, wouldn't the bead not seat properly??
Old Jul 4, 2005 | 05:48 AM
JDM PRO's Avatar
Default Re: Bent rim + inspection? (eXcelonTypeR)
pix would help
Old Jul 4, 2005 | 06:24 AM
BG Enjoi's Avatar
Default Re: Bent rim + inspection? (JDM PRO)
They shouldn't fail you for the tire wear, my car passed and mine had crazy wear, but the center was 2/32 in 2 spots. They measure in 2 spots for the 2/32. Im also pretty positive if your rim, if it is balanced correctly, should pass. Was It from a curb??
Old Jul 4, 2005 | 10:56 AM
tthomass's Avatar
Default Re: Bent rim + inspection? (BG Enjoi)
from a pothole.....you'd have to own a C8 or be really familar with them to know what part i'm talk'n about.............the tire is seated just fine, its like the little piece that flares out. I'd get a pic but can't at the moment...............i figured inspectors call, we'll see how it goes...........should be fine, again its not bad.............thanks!
Old Jul 4, 2005 | 05:38 PM
think about it this way, if he fails you, he's just being better safe than sorry
Old Jul 4, 2005 | 06:19 PM
tthomass's Avatar
i'll find out ahead of time if he'll fail me, if so i'll just wait till i'm home for the weekend where i know i can pass................n. va has some picky bastards over little stuff besides the rim.............thanks for the help
Old Jul 4, 2005 | 06:28 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eXcelonTypeR &raquo;</TD></TR><TR><TD CLASS="quote">think about it this way, if he fails you, he's just being better safe than sorry</TD></TR></TABLE>
And covering his own ***. Liability is a bitch.
Old Jul 4, 2005 | 09:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Liability is a bitch.</TD></TR></TABLE>
agreed
stehigs321
Nov 10, 2010 10:06 AM
sohcvtec91hatch
Mar 10, 2010 06:06 AM
k7q
Mar 4, 2010 12:38 PM
randomtask77
Sep 14, 2008 09:24 PM
A.K.A JDM DRUNKEN MONKEY
Feb 2, 2003 03:07 PM
