am i measuring them wrong?
Old Mar 4, 2010 | 06:03 AM
k7q's Avatar
k7q
Default am i measuring them wrong?
bought a set of rims advertise as 16x8, but now when i recieved them it says 15x7? am i reading it right?
but when i measure them it says 8"
Old Mar 4, 2010 | 06:31 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: am i measuring them wrong?
Rim size (both diameter and width) are measured at the "bead", the indent in the wheel where the inside edge of the tire sits, as shown in the diagram below. They are NOT measured from the outer edge of the lip, which is what you appear to be doing in the photo.
The difference in measurements is typically about an inch, so a 15x7 rim may indeed have dimensions of 8" from the outer edge of the outer lip to the edge of the inner lip (and if you measure the diameter from the edge of one lip to the opposite lip, it may look like 16"). It's still a 15x7 rim.
Old Mar 4, 2010 | 08:09 AM
r.wright's Avatar
ken is right.
by just those numbers stamped i believe its 15x7 +25 4x100.
sorry to hear man
Old Mar 4, 2010 | 09:19 AM
nsxtasy's Avatar
H-T Order of Merit
If they were advertised as 16x8, and they are 15x7 wheels instead, the seller should be willing to give you a full refund if you return them.
Old Mar 4, 2010 | 11:50 AM
k7q's Avatar
k7q
Yea I figure they are 15x7 when I opened the box. Just needed a second opinion. Thanks
Old Mar 4, 2010 | 12:38 PM
DrZFiNeSt's Avatar
Looks like they are 15x7, hope you can work it out with the seller though.
stehigs321
Nov 10, 2010 10:06 AM
turbotime
Jan 20, 2006 05:53 PM
slammed_93_hatch
Jul 17, 2003 11:27 PM
