Problem w/ friends Teg, Code 45
Old Jul 2, 2005 | 01:28 AM
Terrible One's Avatar
Default Problem w/ friends Teg, Code 45
my friend has a 99 ls and it throws code 45 which is "running too lean or too rich". he did a full tune up and also changed the o2 sensor. he bought this "universal" o2 sensor from checkers which didn't come w/ a plug but it was a 4-wire. he followed the instructions and wired it up. the car ran well for couple days then ran like ****. my guess is that this universal o2 sensor is the problem. i have a 00 civic ex and was wondering if i can take off my o2 sensor (since its factory) and put it on his car to see if it makes the car run better. at this moment the car idles funky, has weak power, and gets around 15 miles to the gallon. im hoping that the problem is it just needs a factory type o2 sensor instead of the universal one.
im referring to the o2 sensor off the header
Old Jul 2, 2005 | 08:09 AM
Default Re: Problem w/ friends Teg, Code 45 (Terrible One)
bump
Old Jul 2, 2005 | 10:27 AM
up
Old Jul 2, 2005 | 10:29 AM
mpham529's Avatar
it its the o2 sensor, it would run rich. i work for csk, and im assuming that u didnt get the bosch brand?
Old Jul 2, 2005 | 11:37 AM
Default Re: Problem w/ friends Teg, Code 45 (Painless.)
i think the universal is a bosch brand but im not sure, could that be why?
EDIT: yea its a bosch brand...
Modified by Terrible One at 11:17 AM 7/3/2005
Old Jul 3, 2005 | 09:06 AM
last night i attempt to put my o2 in his but relized that my o2 plug was a female plug and his was a male so it wouldn't plug to his harness which pisses me off. need suggestions
Old Jul 3, 2005 | 09:21 AM
i called autozone and they said the bosch universal is not calibrated to factory settings like the stock one so it will still running shitty.
Old Jul 3, 2005 | 06:00 PM
bump
Old Jul 4, 2005 | 09:51 AM
up
Old Jul 4, 2005 | 09:59 AM
SWEETDUDE's Avatar
Go to a honda dealer and order a stock o2 sensor? Thats my .02 cents.
SLO Sol
Oct 24, 2005 09:59 PM
apok
May 16, 2005 09:52 PM
cu3tip
Oct 18, 2004 08:26 PM
boost fed ls
Aug 31, 2004 07:45 PM
ATS*Mark
Apr 7, 2004 07:06 AM
