Car will not run, Cel 20 and 41?? Help me pls
Have swaped a B18C(obd2a) into my Civic that is/was OBD0.
the Cel shows: 2 long blinks pauses 2 seconds, den 4long followed by a short one.
I get the car to ignite, rev meter shows about 700rpm, but dies right after. i can run it on the starter and it wil trie to start over and over again. Will the 2 cel codes make that the car will not run? Or should it just be in limp mode?
BTW Is the Cel for obd1 the same as on obd2a(jdm)
I have a honda civic 1995 Lsi(Europe DPFI OBD0)
Erro 20:
Electric load ??????
What is it and were can i find it???
Error 41: ithink
Followed the instructions from Boomslang.us, but the o2 was not collor coded, so i tried it out my self.
Yellow -> yellow/black
White -> white
Orange -> Green/black
Gray-> black
can figure it out.
Thanx for any reply
Erro 20:
Error 41: ithink
White -> white
Gray-> black
can figure it out.
Thanx for any reply
Those two codes are not the reason your car wont run. The ELD code(20) means that something is draining your battery. I had that problem before and Ended up being the electrical load detector in the engine fuse box, but my car still ran with it being bad. Try using a new or more powerful battery. As for the o2 code, your car will run, but it will run a little rich if the ecu cant read the o2.
sumoneEK
Nov 22, 2010 11:29 AM
M-EJ1
May 23, 2004 05:49 AM
