emission test fail help
Old Jun 30, 2005 | 12:55 PM
keaps206's Avatar
Default emission test fail help
i just took my emission test and faild the idle part everything else i passed so the guy working there said maybe its my o2 sensor so what should i do ?
i have a 95 si with a jdm b16 sir2 running it with a p30
idle limit hc(ppm) 220
idle emmision 328
idle limit c0% 1.2
idle emission 4.63
Old Jun 30, 2005 | 01:31 PM
SlowestEJ8's Avatar
try changing the o2 sensor?
Old Jun 30, 2005 | 01:41 PM
keaps206's Avatar
yea im gonna try replacing my o2
.:Swig:.'s Avatar
Default Re: (keaps206)
damn that sucks
Old Jun 30, 2005 | 01:44 PM
tele's Avatar
Also, may not be applicable, but if I drive my 95 Coupe EX directly from the garage to the test, it just barely passes. If I go run a quick freeway circuit first, it scores very clean. Make sure the cat is fully heated up before testing emissions.
Old Jun 30, 2005 | 01:46 PM
keaps206's Avatar
yea ill i did was drive around the block since i worked two blocks away i didnt think that was enough
should i replace cap rotar spark plugs pcv and o2 or just get a waiver
Old Jun 30, 2005 | 01:57 PM
tele's Avatar
I would think if you have a prob with the O2 sensor, you'd have a warning light. That's how I knew mine was shot. Got a dash light, extracted the code, replaced the sensor.
Old Jun 30, 2005 | 02:36 PM
underb00steg6's Avatar
Default Re: (tele)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tele &raquo;</TD></TR><TR><TD CLASS="quote">I would think if you have a prob with the O2 sensor, you'd have a warning light. That's how I knew mine was shot. Got a dash light, extracted the code, replaced the sensor.</TD></TR></TABLE>
if your o2 sensor is bad doesnt always mean you'll have a warning light. the o2 could be bad and have no cel.
Old Jul 1, 2005 | 01:15 AM
keaps206's Avatar
anyone?
Old Jul 1, 2005 | 05:25 AM
EE_Chris's Avatar
Looks like you're running quite rich.
How many miles on the O2 sensor? If its got over 60-70k, you can't expect too much out of it.
vtecgsr98
Apr 2, 2005 01:24 PM
See Are X
Jul 13, 2003 07:22 AM
CrxSi707
May 1, 2003 11:41 AM
IloveNewt
Mar 24, 2003 12:53 PM
