Problem with Idle and 2 Cells
Old Apr 1, 2005 | 02:20 PM
vtecgsr98's Avatar
Default Problem with Idle and 2 Cells
Whats up everyone. Well I took off my test pipe and put on my new carsound since im gettin ready to do emissions and i got 2 Cels when i installled it and a rough idle. The scanner said p1298( Manufaturer control fuel air metering) and p0141(o2 sensor heater circuit malfunction Bank 1 sensor 2). I unplugged both of them a couple times and clipped them back in and they still popped on right away. Can anyone tell me what these codes are for? I replaced my front o2 sensor not to long ago but the back is old so could it be that my back o2 sensor just took a **** and i need a new one?? Thanks...
Old Apr 1, 2005 | 06:42 PM
vtecgsr98's Avatar
Default Re: Problem with Idle and 2 Cells (vtecgsr98)
anyone have any ideas??
Old Apr 1, 2005 | 07:34 PM
SYTFU Tommy.'s Avatar
did u plug the o2 senor back in? double check that
Old Apr 1, 2005 | 11:04 PM
92integ_gsr's Avatar
P0128 Cooling System Malfunction
Old Apr 2, 2005 | 04:51 AM
vtecgsr98's Avatar
Default Re: Problem with Idle and 2 Cells (92integ_gsr)
Second code was p1298 not p0128. Yea i unplugged them a couple times and plugged them back in and as soon as i erased the light with the scanner and started the car the light would return with a rough idle and these two codes. Did this like 5 times to make sure...
Old Apr 2, 2005 | 01:24 PM
vtecgsr98's Avatar
Well i wnet outside this morning and check my fuse panel under the dash and sure enough my alternator fuse was blown. I replaced that and it runs fine now..
chris d
Sep 10, 2015 03:35 PM
Magik123
Jun 13, 2007 05:10 PM
kHoA DoGG
26
Dec 28, 2002 09:14 AM
