Main Seal
Old Jun 30, 2005 | 03:20 AM
James's Avatar
Default Main Seal
I am going to replace flywheel and clutch on my 1992 accord with 190k miles and I am wondering if I should also replace main (rear crankshaft) seal while replacing flywheel? Is it a normal practice that we all should try to do? (FYI - the main seal is not leaking and is original.) Thanks.
Old Jun 30, 2005 | 05:51 AM
Chiovnidca's Avatar
Default Re: Main Seal (James)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by James &raquo;</TD></TR><TR><TD CLASS="quote">I am going to replace flywheel and clutch on my 1992 accord with 190k miles and I am wondering if I should also replace main (rear crankshaft) seal while replacing flywheel?</TD></TR></TABLE>
If it's not leaking dont f-with it.
Old Jun 30, 2005 | 06:55 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Main Seal (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
If it's not leaking dont f-with it.</TD></TR></TABLE>
Old Jun 30, 2005 | 11:13 AM
deserthonda's Avatar
MMMMMM 13 yrs old and 190k while tranny is out there is no question i would install a new one it only cost 12-15 dolars and an extra 5 minutes??
Old Jun 30, 2005 | 02:21 PM
Beach Accord's Avatar
terrible advice
replace that ******..... otherwise risk doing it soon down the road AFTER you have re-installed the trans.
do as many seals as you can when you have access.
example: when doing timing belt i always replace cam,crank, and balance shaft seals regardless of condition.
Old Jun 30, 2005 | 03:31 PM
Chiovnidca's Avatar
Default Re: Main Seal (Beach Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beach Accord &raquo;</TD></TR><TR><TD CLASS="quote">terrible advice
replace that ******..... </TD></TR></TABLE>
I dissagree, very rarely see a leaking rear main. The that do leak are usually still under warranty.
Old Jun 30, 2005 | 03:44 PM
yo Chi buddy i repsect you .. you seem to know ur **** but this time i have to strongly disagree with you,,,,,, i agree ,,very rare do i see them leaks as well but i always replace it while tranny is off as preventive maintanance ehy it could only last a few weeks?? months?? and hell it only takes 5 minutes to do and if it does leak how am i going to explain to customer that he needs to pull the tranny out again when we were just there mmmm mmmmmm i won,t take the risk .
Old Jun 30, 2005 | 08:26 PM
accordredliner's Avatar
* B A N N E D *
is this a DIY job?
G2_Fella
Aug 18, 2008 08:37 AM
hidiouskinky
Jun 23, 2008 07:26 PM
FuNkDrSpOt
Oct 7, 2007 02:08 PM
SpoolnEG6
Aug 5, 2005 05:42 AM
GRAVEDIGGER
Sep 2, 2004 11:57 AM
