Main Seal
Main Seal
I am going to replace flywheel and clutch on my 1992 accord with 190k miles and I am wondering if I should also replace main (rear crankshaft) seal while replacing flywheel? Is it a normal practice that we all should try to do? (FYI - the main seal is not leaking and is original.) Thanks.
Re: Main Seal (James)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by James »</TD></TR><TR><TD CLASS="quote">I am going to replace flywheel and clutch on my 1992 accord with 190k miles and I am wondering if I should also replace main (rear crankshaft) seal while replacing flywheel?</TD></TR></TABLE>
If it's not leaking dont f-with it.
0x5359-0055
Re: Main Seal (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">
If it's not leaking dont f-with it.</TD></TR></TABLE>
terrible advice
replace that ******..... otherwise risk doing it soon down the road AFTER you have re-installed the trans.
do as many seals as you can when you have access.
example: when doing timing belt i always replace cam,crank, and balance shaft seals regardless of condition.
terrible advice
Re: Main Seal (Beach Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beach Accord »</TD></TR><TR><TD CLASS="quote">terrible advice
replace that ******..... </TD></TR></TABLE>
I dissagree, very rarely see a leaking rear main. The that do leak are usually still under warranty.
yo Chi buddy i repsect you .. you seem to know ur **** but this time i have to strongly disagree with you,,,,,, i agree ,,very rare do i see them leaks as well but i always replace it while tranny is off as preventive maintanance ehy it could only last a few weeks?? months?? and hell it only takes 5 minutes to do and if it does leak how am i going to explain to customer that he needs to pull the tranny out again when we were just there mmmm mmmmmm i won,t take the risk .
FuNkDrSpOt
10-07-2007 02:08 PM
