built b16 or a gsr boosted
Old Jun 29, 2005 | 07:40 AM
onesikcivic's Avatar
Default built b16 or a gsr boosted
allright i got a stock b16a1 and i just boosted it with a t3/t04 turbo, and it just feels slow, turbo doesnt spool till around 5500/6000 and dogs till it kicks in, i raced a newer z28 and he just pulled hard 1st and 2nd and then i started to catch up and ended up passing him, but thats a stock z28
so heres the question, should i keep the turbo kit and build the b16 or do u think it will be better to ls/vtec it sense i already have the head, or i was thinking about buying a gsr so i can have a little more torque or power to spool the turbo so it kicks on sooner
also, out of them which one will be a cheaper upgrade?
Old Jun 29, 2005 | 07:49 AM
pv2dickman's Avatar
Default Re: built b16 or a gsr boosted (onesikcivic)
tune your b16
Old Jun 29, 2005 | 07:53 AM
we tuned it with bre
Old Jun 29, 2005 | 08:06 AM
pv2dickman's Avatar
Default Re: (onesikcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onesikcivic &raquo;</TD></TR><TR><TD CLASS="quote">feels slow, turbo doesnt spool till around 5500/6000 and dogs till it kicks in</TD></TR></TABLE>
ls/vtec or a gsr..between the two.. i would go with the gsr
less time.. money.. and headache
unless you into building engines and such..
what is your setup exactly
Old Jun 29, 2005 | 08:17 AM
Rod.'s Avatar
Default Re: (pv2dickman)
no point to buying a gsr when you have a good platform..build the b16
Old Jun 29, 2005 | 03:33 PM
yea i think im gonna build the b16 to be able to hold more boost, i guess its time to search for some setups, anyone have a recommendation while i search
Old Jun 29, 2005 | 05:38 PM
D-t's Avatar
D-t
You sure you don't have a leak somwhere?
5500/6000 rpms when it starts to spool doesn't seem right.
What is the specs on the turbo?
Old Jun 29, 2005 | 07:16 PM
rmcdaniels's Avatar
I vote build the B16, that's what I did, couldn't be happier with it, and stock Z28's don't pull on me in any gear.
Old Jun 29, 2005 | 08:47 PM
beerbongskickass's Avatar
Default Re: (rmcdaniels)
Turn the boost up...
Old Jun 29, 2005 | 09:23 PM
well im not exactly positive i have a leak somewhere its possible, is there a way to check it and ill get the specson the turbo tommorrow, i bought it off my buddy alil while back after her sent it out to get rebuilt and forget the exact specs, should i lower vtec a little bit and see if that helps spool it better i think its set at 5200
93sihatchy
Jun 3, 2007 02:06 PM
Lil wayne
May 9, 2007 12:56 PM
Hazymix
19
Oct 12, 2006 12:51 PM
Sniper*oK
27
Nov 4, 2005 05:18 PM
tony n.
Apr 24, 2005 12:11 PM
