high hp guys, what valves do you run?
Old Jun 28, 2005 | 03:16 PM
B16Civic93's Avatar
Default high hp guys, what valves do you run?
just curious what valves you guys are running? are stock honda valves good with a high horsepower setup? planning on no more than 400whp didnt know if i should upgrade the valves while i had the head off, i'm going to get stiffer springs and ti retainers, new valveguides also,and a valve job, i wasnt sure about the valves though. if i need an upgrade what type and brand?
Old Jun 28, 2005 | 03:23 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: high hp guys, what valves do you run? (B16Civic93)
it isnt hte high horsepwer you need to worry about it is where the engine is going to be rev'ing. my choice was Racing Engine Valves. REV Valves. stainless, swirl cut, was told they were the same manufacturer as ferra but i am not worried about it if they arent. they still have a good name.
Old Jun 28, 2005 | 03:28 PM
careawholelot's Avatar
Default Re: high hp guys, what valves do you run? (boostedcivicsir)
i'm using supertech
Old Jun 28, 2005 | 03:31 PM
B16Civic93's Avatar
probably not much past 9000 if it goes that high, i just figure i might want to replace the springs and retainers while the head is out and apart. but valves are expensive and i really dont want to replace them if i dont have to.
Old Jun 28, 2005 | 03:33 PM
Mr. Badwrench
my first engine never saw anything over 8000 and the stockers held up fine but now i am looking at 9600 plus so i went with the good stuff.
Old Jun 28, 2005 | 04:45 PM
uglyasscivic's Avatar
Supertech Valves, spring and retainers.
Old Jun 28, 2005 | 04:55 PM
rondigs's Avatar
Default Re: high hp guys, what valves do you run? (uglyasscivic)
ITR Porcelin coated intake valves. Ferrea SS oversized exhaust valves.
Old Jun 28, 2005 | 05:55 PM
PrettyLude's Avatar
ferrea and supertech gets my vote
Old Jun 29, 2005 | 02:58 PM
B16Civic93's Avatar
Default Re: (PrettyLude)
well would you suggest upgraded valves in a 400whp car or do you guys think that the stock b16a valves will hold up. i mean i'm sure i'll never see anything higher than 9000 and that is a high estimate. let me know. thanks
also what brand springs and retainers should i run?
Old Jun 29, 2005 | 05:03 PM
White Smoke's Avatar
i my honda
Global Mod
Ferreria SS .5mm Oversized Valves
With
Portflow Dual Valve Springs and Ti Retainers Here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Civic93 &raquo;</TD></TR><TR><TD CLASS="quote">well would you suggest upgraded valves in a 400whp car or do you guys think that the stock b16a valves will hold up. i mean i'm sure i'll never see anything higher than 9000 and that is a high estimate. let me know. thanks</TD></TR></TABLE>
I would not go past 8400 on stock b16 valve train; especially if you have an older B16a. If you want to rev to 8600 you need new springs, at least!
Old Jun 29, 2005 | 09:36 PM
Tooned's Avatar
Default Re: high hp guys, what valves do you run? (White Smoke)
Endyn .5mm oversize Crower dual springs and Titanium retainers with GSR keepers
Old Jun 30, 2005 | 12:25 PM
B16Civic93's Avatar
Default Re: high hp guys, what valves do you run? (Tooned)
i know i need new springs and titanium retainers to rev that high, i plan on upgrading them at least, but i wasnt sure if i need to upgrade the valves themselves. would you suggest it for 400whp? how much did you guys pay for your new valves?
Old Jun 30, 2005 | 12:28 PM
platinum00's Avatar
running supertech, good price and have not had any issues over 9k
platinum
Old Jun 30, 2005 | 12:41 PM
RyanEJ8's Avatar
Stock valves will work for 400whp.
Agip
Jan 18, 2005 08:18 PM
advanracing62
Oct 3, 2002 09:43 AM
austrian type-R
Sep 30, 2002 03:08 PM
infinkc
Dec 6, 2001 11:35 AM
Smoothy
Sep 23, 2001 05:38 PM
