F22A Gears... will anything transfer over into the H22A tranny?
Old Jun 28, 2005 | 05:08 AM
The_Head's Avatar
Default F22A Gears... will anything transfer over into the H22A tranny?
I'd like to have either the F22A final drive and/or the F22A 5th gear in my H22A tranny.... does anyone know if they will work, and when I say "work", I mean "plug and play" i.e. no machining required.
TIA
John
Old Jun 28, 2005 | 05:21 AM
Sam1am26's Avatar
Default Re: F22A Gears... will anything transfer over into the H22A tranny? (The_Head)
Bump... It should but I want to know for sure too...
Old Jun 28, 2005 | 06:05 AM
iakona's Avatar
man. we've been round and round on this one. i want to know too, but according to my local guy, it doesn't work. things don't line up correctly.
Old Jun 28, 2005 | 07:02 AM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: (iakona)
some guy here said he was putting an accord 4th and 5th on his h22 tranny but never heard if he got it to work rite
Old Jun 28, 2005 | 09:31 AM
JonGP4's Avatar
Default Re: (raylude)
search, its been covered numberous times, the mainshaft and counter shafts are completely different in size, not only will the gears not slide onto the shafts they won't line up at all.. the final drive between the tranys is exactly the same.. changing it won't do anything
Old Jun 28, 2005 | 09:52 AM
machine4321's Avatar
well the h23 and hss counter and main shafts are the same part number
with slight shaving the h23 5th gear would have fit but i ran out of tim an money to complete it ...
all syncros and sleeves will work except for 3rd and 4th as the hub/syncro/sleeve is bigger in the h22
but why would you want to do this other then the 5th gear ?
oh and depending on what final drive is in the acord box will depend on what counter and main shafts are in the tranny
Old Jun 28, 2005 | 09:54 AM
BB6racer's Avatar
i had my tranny rebuilt a month ago, and i have an accord 5th gear in my tranny. the shop accidentally put 3rd, 4th, and 5th accord gears in originally, but i brought it back and they swapped in prelude 3rd and 4th again. the 92-96 prelude si has the same gearing as an accord. so it is possible, i just don't know wjat kind of spacers are needed, if any are needed at all. hope this helps.
Old Jun 28, 2005 | 12:36 PM
Sam1am26's Avatar
Taken from here... https://honda-tech.com/zerothread?id=801212
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">Tried it and it won't work unless you want to make custom shims. Also tried to put a H23 fifth gear in a H22 tranny and it won't work either. Despite all of the Honda standardizations the tranny gears are not one of them. Sorry.
The Pirate</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">Quite honestly, I don't see why they WOULDN'T be interchangeable.......guess I'll be checkin out my new Helm's when i get home later.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda318dx &raquo;</TD></TR><TR><TD CLASS="quote">I have swapped between accord and prelude trannies as well.. No problem
Andy, if you like the track, I would NEVER recomend changing the prelude gearing, its the best out there... </TD></TR></TABLE>
Old Jun 28, 2005 | 12:44 PM
as i siad in my threads about the h23 5th ...every gear it self has a diff spacing when comparied to the relative gear in the h22 ..but they all come out to about 2-3mm diff in the end ..so the 5th gear only needs to be machine donw a few mm
the only reason it needs to be machined down is so the bearing on the countershaft can slide up into the housing /snap ring
Old Jul 1, 2005 | 04:52 AM
The_Head's Avatar
hmph, I was told my tranny had an H23 5th in it already, but the H22 and H23 5th gears aren't that much different (numerically) so I am still cruising at pretty high RPMs on the highway.
So I guess I'll just have to settle for what I have then... I could get an F22 tranny, but that's too long for my tastes.
Old Jul 1, 2005 | 05:00 AM
Sam1am26's Avatar
I am currently using an H23 tranny and I hate 5th gear... I do a lot of highway driving and I hate being in boost in 5th gear... I still think it is doable...
Old Jul 1, 2005 | 05:40 AM
OaksRacing's Avatar
Default Re: F22A Gears... will anything transfer over into the H22A tranny? (Sam1am26)
We run Vtec final drive with F22 gears.
Old Jul 1, 2005 | 12:16 PM
The_Head's Avatar
Default Re: F22A Gears... will anything transfer over into the H22A tranny? (OaksRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OaksRacing &raquo;</TD></TR><TR><TD CLASS="quote">We run Vtec final drive with F22 gears. </TD></TR></TABLE>
I'm sure that's great for a turbo application...
but did you have to do any modifications?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnGP4 &raquo;</TD></TR><TR><TD CLASS="quote">the final drive between the tranys is exactly the same.. changing it won't do anything</TD></TR></TABLE>
According to my info... F22A FD = 4.062 H22A FD = 4.266.... 5% shorter... I wouldnt mind spinning 5% less revs, since I'm pretty sure my G23 VTEC setup is going to have alot more than 5% more torque to compensate.
Old Jul 2, 2005 | 04:53 AM
iakona's Avatar
yeah, but what i think we all really want is our gearboxes with the .702 F22 final drive.
Old Jul 2, 2005 | 07:29 AM
94Vtecluder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Head &raquo;</TD></TR><TR><TD CLASS="quote">I'd like to have either the F22A final drive and/or the F22A 5th gear in my H22A tranny.... does anyone know if they will work, and when I say "work", I mean "plug and play" i.e. no machining required.
TIA
John</TD></TR></TABLE>
If you don't like the H22 tranny why not just get a B &lt;-&gt; H series tranny adapater that's out there and slap on a B18C tranny?
Old Jul 2, 2005 | 07:38 AM
Sam1am26's Avatar
Default Re: F22A Gears... will anything transfer over into the H22A tranny? (94Vtecluder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder &raquo;</TD></TR><TR><TD CLASS="quote">
If you don't like the H22 tranny why not just get a B &lt;-&gt; H series tranny adapater that's out there and slap on a B18C tranny?</TD></TR></TABLE>
Probably because they are super expensive and his hatch is already modified for an H/F series tranny...
Old Jul 3, 2005 | 08:49 AM
OaksRacing's Avatar
No modifications.[QUOTE=The_Head]
Old Jul 3, 2005 | 03:48 PM
raylude's Avatar
so the gears are interchangeable with no mods? or is that just the final gear?
Old Jul 3, 2005 | 03:55 PM
Sam1am26's Avatar
Default Re: F22A Gears... will anything transfer over into the H22A tranny? (raylude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raylude &raquo;</TD></TR><TR><TD CLASS="quote">so the gears are interchangeable with no mods? or is that just the final gear?</TD></TR></TABLE>
Just the final drives... But Honda318dx said this to me...
(11:17 AM 7/1/2005) Honda318dx: I have swaped FDs, but I'm SURE that some of the gears are interchangeable, not exactly sure how though, might have to mix and match syncros and selectors
Old Jul 5, 2005 | 05:01 AM
The_Head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam1am26 &raquo;</TD></TR><TR><TD CLASS="quote">
Probably because they are super expensive and his hatch is already modified for an H/F series tranny...</TD></TR></TABLE>
He's right...
and H trannies are alot less expensive then B's.
Please elaborate Oaks Racing... there seems to be mixed information on this topic. Some say yes, some say no..
would also like to know part numbers for parts needed to swap the final drive gear, thanks
AnthonyG2003
Aug 9, 2006 01:37 PM
accord93racer
Feb 21, 2006 05:33 AM
H22 EH!
Mar 12, 2005 06:18 AM
User 5426
Jul 24, 2004 09:10 PM
HotWheelz
Oct 7, 2002 05:14 PM
