Major Richness Problem as well as others.
Setup: 1997 CX hatch with 1999 EX VTEC swap and OBD1 converted ECU.
Ok, I got my auto P06 ECU converted and chipped.
Anyhoo, he says he put a stock D16Y8 map on the chip with light mods added. I have a 4 into 1 Holley Airmass header (awesome header by the way), MSD SCI, Nology Hotwires, Nology Profire coil, 2 1/4" full catless exhaust, and a cold air intake.
First off its throwing a solid CEL, no blinks, no codes just solid, yet the car runs. Secondly its running 100% rich 95% of the time when I datalog with uberdata and ECUcontrol. The O2 sensor readings were 0 at idle, or 0-7 or 8ish. Then at rev the O2 sensor went to 17-45. I have no idea how to read O2 sensor readings so maybe you guys can help.
The most recent addition aside from the ECU and OBD1 harness is the headers. I ahve to lengthen the wire by cutting and splicing the O2, could that have anything to do with it besides the supposedly bad burned chip?
I put the chip in my friends 99 Si with the same P06/P28 converted ECU and his runs flatout great aside from the solid CEL. His is stoich 85% of the time and doesn't seem to have the same problems. Any ideas?
Modified by Hatch_Back_97 at 12:10 PM 6/28/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_Back_97 »</TD></TR><TR><TD CLASS="quote">The most recent addition aside from the ECU and OBD1 harness is the headers. I ahve to lengthen the wire by cutting and splicing the O2, could that have anything to do with it besides the supposedly bad burned chip?</TD></TR></TABLE>
This is most likely the source of the richness. Did you solder and shrinkwrap the splice or just tape it together?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_Back_97 »</TD></TR><TR><TD CLASS="quote">I put the chip in my friends 99 Si with the same P06/P28 converted ECU and his runs flatout great aside from the solid CEL. His is stoich 85% of the time and doesn't seem to have the same problems. Any ideas?
I have no expertise, but it sounds like bad code on the chip.
streetstylenperformance
Feb 6, 2004 04:08 PM
tinkerbell
Jan 8, 2003 12:39 AM
Projectg2i
Dec 16, 2002 02:30 AM
