gauge cluster repair
Old Jun 26, 2005 | 02:12 AM
kobeRy_si's Avatar
Default gauge cluster repair
eh. i broke the needle off my temp gauge.. can this be repaired or do i have to buy a whole new one>? btw, cluster is 99-00 si.
Old Jun 26, 2005 | 07:18 AM
KtHaNxBai's Avatar
how the hell do u do that?????
Old Jun 26, 2005 | 10:25 AM
nota-eg's Avatar
Default Re: (galaxykid70)
You could probably just get another needle and stick it on.
Did you break the needle, or the part inside of the cluster that the needle connects to?
Old Jun 26, 2005 | 12:30 PM
onefstek's Avatar
if you broke the needle and half of the needle shaft is still in the cluster, then you have to buy new gauge.
ie: if you broke the tach needle, then you have to buy new tach gauge not the whole cluster
Old Jun 26, 2005 | 02:04 PM
kobeRy_si's Avatar
Default Re: (onefstek)
damn it! i broke the needle, the silver shaft is still inside the cluster..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefstek &raquo;</TD></TR><TR><TD CLASS="quote">ie: if you broke the tach needle, then you have to buy new tach gauge not the whole cluster</TD></TR></TABLE>
can i do the same for the temp/fuel gauge side&gt;&gt;??
Old Jun 26, 2005 | 06:45 PM
onefstek's Avatar
yes you can, but you have to buy the fuel/temp gauge as a unit. unless you find one from another car that you can take off the needle safelly.
FYI: to take out the needles on the civic clusters is harder then the integra ones.
for the civic you have to use a heat gun or a hair drier to worm up the needle shaft and then use a fork to pull up straight.
that way you don't brake the needle.
BTW: I found that hair drier works better with less chance of melting the gauges.
raverx3m
Nov 10, 2013 08:18 AM
RACE2WARPED
Jan 29, 2011 07:54 PM
nubs
Jan 8, 2004 10:29 PM
h82lose
Feb 3, 2003 04:46 PM
