Valves adjustment problems!!!!!!!!!!!
I have a 88 crx si witha minime swap (a6/z6) and its been running good for the past 2 month.Couple weeks ago i decide to readjust the valves in the correct order (1342).009E/.007I.Whenever id put everything back together and id start the car i heard the valve ticking even worst.So id readjust them again at.008E/.006I and still the same.Also my car sound different tru the exhaust.It sound like a WRX.Can somebody tell me why is doing those noise.Thanx.
english lessons will fix that
HAhah, ok just kidding
make sure you used the correct gauges , did you leave one in there ?
do a compresion and leakdown test to make sure that you didnt drop a valve, or knock a retainer/keeper loose. I hope not.
Yes its my second language so give me a break.Ill check it out 2morrow and see what am i missing.Any more suggestions?
^^thats what im thinking too.
Did you Rotate the Crank a 1/4 turn on the Cam gear each time you adjusted a cyl's valve lash?
And did you do it with the motor COMPLETELY COLD?
If not then theres your problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kryogen »</TD></TR><TR><TD CLASS="quote">
Did you Rotate the Crank a 1/4 turn on the Cam gear each time you adjusted a cyl's valve lash?</TD></TR></TABLE>
I'll put $20 on that being the problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai »</TD></TR><TR><TD CLASS="quote">
I'll put $20 on that being the problem.</TD></TR></TABLE>
Where's my $20.I did the 1/4 of a turn on the cam gear to the right (turning the cam gear toward the firewall).The car haven't been moved for a couple of days whenever i did them.Also i try .011E/.009I thats the max i can go by the book.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rexified »</TD></TR><TR><TD CLASS="quote">umm arnt you suppose to turn the cam gear towards the front? yea im pretty sure you did it backwards. the crank/cam works counter clockwise.</TD></TR></TABLE>
Thats how i did it.Counter clockwise goes toward the firewall,to the right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91sihatch »</TD></TR><TR><TD CLASS="quote">umm you need to think again which way a clock turns
Counter clockwise is to the LEFT</TD></TR></TABLE>
Alright.I'm goin to try to the left and 1342 and ill let u guys know.Thanx for the help.
Counter clockwise is to the LEFT</TD></TR></TABLE>Alright.I'm goin to try to the left and 1342 and ill let u guys know.Thanx for the help.
Does it really matter which way you turn the crank? As long as you are measuring the correct cylinder at 1/4 turns from TDC, I think it's ok... people correct me if I'm wrong... because I may be really wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kim_2_da_chee »</TD></TR><TR><TD CLASS="quote">Does it really matter which way you turn the crank? As long as you are measuring the correct cylinder at 1/4 turns from TDC, I think it's ok... people correct me if I'm wrong... because I may be really wrong.</TD></TR></TABLE>
Yeah it matters because you have to do it in Firing Sequence with the way the motor turns, so 1342 the Cyl's will be a TDC when you adjust., If you do it backwards you will not get it right.
I shouldve made that bet with you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rexified »</TD></TR><TR><TD CLASS="quote">ooo pittsburgh! just noticed
plus whats so bad about sounding like a wrx
i like the deep rumble</TD></TR></TABLE>
Trust me, i liked the sound but i want my car running right.
i like the deep rumble</TD></TR></TABLE>Trust me, i liked the sound but i want my car running right.
Yeah it matters because you have to do it in Firing Sequence with the way the motor turns, so 1342 the Cyl's will be a TDC when you adjust., If you do it backwards you will not get it right.</TD></TR></TABLE>
So clockwise is correct? or counter clockwise... (i didnt understand the last post about which is correct)
Frost7177
Dec 15, 2008 08:06 AM
c-way
Aug 30, 2004 08:03 AM
