balance shaft belt removal
Old Jun 24, 2005 | 08:39 AM
dfoxengr's Avatar
Default balance shaft belt removal
would it be ok to just remove the balance shaft belt and run the car safely?
wouldnt this take the load off of the crank as well. but not change anything with the oil pressure?
Old Jun 24, 2005 | 10:57 AM
IHateJDM's Avatar
Default Re: balance shaft belt removal (hybridvteceg)
yes, you don't save the 8 lbs that you would if you got a block off kit, but it does free up the parasitic drag on the crank, while keeping the bottom end oil-leak free. As far as it being safe, well its as safe as any H not running the balance shafts. I'm not saying it isn't safe, but I know there have been many debates on this, and I'm not starting another one .
Old Jun 24, 2005 | 11:30 AM
skunked's Avatar
Default Re: balance shaft belt removal (IHateJDM)
https://honda-tech.com/zerothread?id=1278213
Old Jun 24, 2005 | 03:10 PM
dfoxengr's Avatar
Default Re: balance shaft belt removal (skunked)
yeah i saw their kit, but i didnt feel like taking apart the bottom end to install it.
Old Jun 24, 2005 | 03:13 PM
dfoxengr's Avatar
what exactly consists of the 8-10 lbs? just the outer casing with the gear?
im just getting into H series sorry
Old Jun 24, 2005 | 03:54 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">what exactly consists of the 8-10 lbs? just the outer casing with the gear?
im just getting into H series sorry</TD></TR></TABLE>
The shafts themselves are pretty heavy. Same with the F's. I just ditched my belt on my current motor but I will be using his kit on my next build
Old Jun 24, 2005 | 05:05 PM
dfoxengr's Avatar
what exactly are the shafts, and where are they, B's dont have them
Old Jun 25, 2005 | 09:26 AM
skunked's Avatar
They run parell right above the crank.
Here ya go.
Old Jun 25, 2005 | 01:45 PM
dfoxengr's Avatar
oh ok. i see now. can you just pull them out and plug the holes in the side of the block that you have circled, and not do anything inside the motor?
Old Jun 25, 2005 | 01:53 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">oh ok. i see now. can you just pull them out and plug the holes in the side of the block that you have circled, and not do anything inside the motor?</TD></TR></TABLE>
Nope, I wish. There is a couple oil passages that need to be plugged along with the two external shaft plugs. That's why the kit is so nice, it has all the plugs and directions.
Old Jun 25, 2005 | 01:54 PM
dfoxengr's Avatar
cool i didnt actually understand what they were, now i do
Old Jun 25, 2005 | 02:01 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">cool i didnt actually understand what they were, now i do </TD></TR></TABLE>
I hear ya. I was a B series guy until about one year ago when I bought my first H block and I didn't know what the hell those things were when I first got the block....
Make sure you upgrade to a manual T-Belt tensioner too.
https://honda-tech.com/zerothread?id=549516
Old Jun 25, 2005 | 04:14 PM
dfoxengr's Avatar
yeah i just figured that thing out like a week ago, lol me
lude512
May 28, 2013 06:30 PM
daymkimchee
Nov 30, 2009 11:34 PM
Finest
Aug 17, 2006 06:25 PM
BB6racer
Sep 5, 2005 07:33 AM
satan_srv
Nov 21, 2002 02:15 PM
