idle question.
Old Feb 12, 2002 | 05:10 PM
escocrx's Avatar
Default idle question.
i have a b16a in my rex. it has pulsating idle though. 1k to 2k up and down when idleing. what could this be?
my ideas.
TPS?
O2 sensors?
got anymore ideas? any will be appreciated. thanx alot
Old Feb 12, 2002 | 06:47 PM
Aron Parsons's Avatar
Default Re: idle question. (escocrx)
sounds like a vaccum leak. check all your hoses. also, try cleaning out your EAVC (unbolt it, clean off all the carbon build-up, and clean off the screen). i just did this and it improved my idle ALOT! it never stutters, moves, etc.
Old Feb 12, 2002 | 06:50 PM
VTC_CiViC's Avatar
Default Re: idle question. (OvERaCiD)
Bleed the coolant too!
Old Feb 12, 2002 | 10:03 PM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
Check your throttle body gasket for leaks too.
-Todd
Old Feb 13, 2002 | 06:05 AM
NawTeeCRX's Avatar
I have a quirky problem in my rex too. I've got a '99 d16y8 w/ pg7 ecu that had just been installed a week ago. At temperature, it stays right between 700-800 rpm, then dips every now and then... sometimes almost stalling. It did actually stall a couple of times. Otherwise, the motor is excellent.
Old Feb 13, 2002 | 08:58 AM
JDM HYBRID's Avatar
Default Re: idle question. (NawTeeCRX)
I HAD THE SAME PROBLEM..........
OK IS YOUR TIMING ADVANCED? WELL PUT IT BACK TOP STOCK!
THEN YOU CAN MESS WITH THE VACUUM SCREW ON THE MANIFOLD THAT WILL MAKE IT STOP.........JUST RIASE OR LOWER IT WHATEVER IS NEEDED, JUST LISTEN TO YOU ENGINE, AND TRY DIFF SETTINGS....
THAT SHOULD STOP IT..........
Old Feb 13, 2002 | 09:01 AM
PatEJ6's Avatar
Default Re: idle question. (JDM HYBRID)
JMD HYBRID, there is a button on your keybord left side about in the middle called Caps Locks. Push it once.
Old Feb 13, 2002 | 09:03 AM
JDM HYBRID's Avatar
Default Re: idle question. (SpeedyPat)
ARE YOU TRYING TO SAY SOMTHING.......DONT TAKE IT PERSONAL IF MY CAPS GET YOU SHOOK.......BUSTER
Old Feb 14, 2002 | 07:50 PM
rice_classic's Avatar
I let it do it.. i've had a 87 jetta gl, 89 hb si, and 88rex si. All idled about 600-800 with an occasional dip.. When it goes low (way low) just blip the throttle and it will go back to normal. If it refused to or if it actually dies when it dips THEN you have a problem. btw: if you have your a/c on, when the a/c clutch catches then it can cause the idle to dip momentarily.
Old Feb 14, 2002 | 09:00 PM
vsual's Avatar
my ideas.
TPS?
O2 sensors?
99% its your spark plugs. when was the last time you did a tune up on it?? what type of spark plugs are you using??
BravoTango
Feb 27, 2020 06:14 AM
Midori Green
Jan 3, 2007 03:13 PM
foam
Jan 1, 2006 01:25 PM
92HB_HB
Sep 12, 2004 03:40 PM
Bondcivic007
May 9, 2003 12:18 PM
