Best way to get to wiring from back speakers?
Old Feb 12, 2002 | 04:24 PM
CW-ITR-329's Avatar
Default Best way to get to wiring from back speakers?
I went to install one of those Converters that convert the speaker wire to a RCA, and I couldn't figure the best and easiest spot to tap in. Has anyone done this?
Thanks
Old Feb 12, 2002 | 04:29 PM
Rboosted717's Avatar
Default Re: Best way to get to wiring from back speakers? (CW-ITR-329)
best way IMO is to just tap off the speaker wire anywhere. You can pull the stock speaker and solder a tap off the speaker lead, however I would just tap off of anything. One thing to note is tap off in a location where the convertor will get little to no interference from other stuff.
Old Feb 12, 2002 | 04:39 PM
typer100's Avatar
Default Re: Best way to get to wiring from back speakers? (Rboosted717)
I agree! It's what I did back then when I used to own a R. I've removed the cover, tapped a new wire and pass it all the way to the trunk. I had a spare trunk cover (10$ with 6" hole already made) from a scrap yard and put 2 6" Infinity speaker on it... Et voila...
But I like to talk to the "engineer" who designed the rear speaker location... What a moron
Old Feb 13, 2002 | 01:41 PM
MHhonda99's Avatar
Default Re: Best way to get to wiring from back speakers? (typer100)
Here is what I usally do. Just take out the head unit, insall it there. And the the rca's to the back. That way when you upgrade to a better cd-player that has rca's, you already have the rca's ran. And it won't interefere with it there. It works great on a durnago, cavilier, civics, and so on. but y aren't you buying a cd-player right away? Line-out converters are a waste, its such a rob of power. THere is no such thing as a good converter. Just get a good cd-player!!! I put the converter on the durango becasue the customer didn't want to lose their steering wheel controls. But is robs so much sounds. trust me. a good pioneer cd-player makes a HUGE difference.
Old Feb 14, 2002 | 08:56 AM
CW-ITR-329's Avatar
Default Re: Best way to get to wiring from back speakers? (MHhonda92)
Do you have to remove all the plastic to pull the back speaker or do you just pop the cover off? Ryan
Old Feb 23, 2002 | 11:37 PM
nfn15037's Avatar
Fer christ sakes man, just go look at the damn thing
Old Feb 24, 2002 | 06:22 AM
o_Rage_o's Avatar
Default Re: Best way to get to wiring from back speakers? (nfn15037)
I Like MHonda92's Idea! Do the work once, and run the rca converter off the headunit!, this way when you upgrade your deck, the wirings already done for you, and you just unhook the rca converter and plug it into your deck!
Then again, for simplicity, just splice it from wherever you can if you don't have the time
-Rage
Old Feb 24, 2002 | 07:33 PM
2K_TEG's Avatar
Default Re: Best way to get to wiring from back speakers? (o_Rage_o)
Just use the factory wiring. You are going to have to run rcas so run speaker wire with it and hook it up behind the head unit. if you are not going to sound offs that is all you need. Especially helpful for front door speakers.
one power
Feb 28, 2007 08:18 PM
EM1VtecSi
Feb 18, 2005 02:19 PM
Odessa
Audio / Security / Video
19
Jul 23, 2004 07:55 PM
foofighter
Aug 24, 2003 01:24 PM
94civicx
Apr 17, 2002 08:25 PM
