need help please....
Old Jun 22, 2005 | 03:08 PM
gsrcivic619's Avatar
Default need help please....
I take my car into the shop to get it dyno tuned because it had been bogging a lot. I thought it was because i had messed with the vtec controller, but that wasnt it because i got it dyno tuned and the bogging still continues. The bogging is like pretty much all the time. IF i step on the gas it kinda goes away but still it bogs badly. I think my valve cover gasket is leaking oil... Can anyone please help me out and give me some ideas on what it could be?? injectors? anyone? please!
Old Jun 22, 2005 | 03:09 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: need help please.... (gsrcivic619)
what was your a/f? have you replaced the fuel filter recently?
Old Jun 22, 2005 | 03:20 PM
Default Re: need help please.... (boostedcivicsir)
my fuel pressure regulator is set at like 42 psi and when i rev it it goes up to about 52 psi, and naw i havent replaced the fuel filter
Old Jun 22, 2005 | 03:22 PM
Mr. Badwrench
thats a 15$ bullet you can try yourself.
Old Jun 22, 2005 | 03:28 PM
boostn5Ghaba's Avatar
I had a similar problem, turned out to be the spark plugs. It was fouled and gapped wrong. Check to see if it's that.
Old Jun 22, 2005 | 03:51 PM
98b18black's Avatar
Default Re: (boostn5Ghaba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostn5Ghaba &raquo;</TD></TR><TR><TD CLASS="quote">I had a similar problem, turned out to be the spark plugs. It was fouled and gapped wrong. Check to see if it's that.</TD></TR></TABLE>
Yea...check all your basics first....Plugs, Wires, etc...
Old Jun 22, 2005 | 03:52 PM
Default Re: (95d15red)
alright thanx a lot guys i will check my spark to see if thats the problem.
Old Jun 28, 2005 | 12:15 PM
ok, so i've tried replacing the fuel filter, spark plugs, and my wires, THE CAR STILL BOGS WTF.. and now when i turn it on the rpm's kinda begin to surge up and down... Someone Please help me out it would be greatly appreciated.
Old Jun 28, 2005 | 12:27 PM
bump
Default Re: (gsrcivic619)
bump
Old Jun 29, 2005 | 11:26 AM
98b18black's Avatar
Have you tried the fast idle control valve being loose....
Old Jun 29, 2005 | 11:27 AM
98b18black's Avatar
they have a tendency to work themselves loose...it's underneath your throttle body...actually made on to it....there is a plate that is held on by 2 screws, loosen those, take them out and see if the valve inside is loose...if so tighten it
BKJJ77
Mar 5, 2012 08:41 AM
chads
Mar 29, 2008 01:28 PM
latinracerct
Oct 19, 2006 01:57 PM
92hatchling
10
Jan 29, 2006 03:33 PM
-16V-
Mar 20, 2004 05:16 AM
