need help please....
I take my car into the shop to get it dyno tuned because it had been bogging a lot. I thought it was because i had messed with the vtec controller, but that wasnt it because i got it dyno tuned and the bogging still continues. The bogging is like pretty much all the time. IF i step on the gas it kinda goes away but still it bogs badly. I think my valve cover gasket is leaking oil... Can anyone please help me out and give me some ideas on what it could be?? injectors? anyone? please!
Re: need help please.... (boostedcivicsir)
my fuel pressure regulator is set at like 42 psi and when i rev it it goes up to about 52 psi, and naw i havent replaced the fuel filter
Re: (boostn5Ghaba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostn5Ghaba »</TD></TR><TR><TD CLASS="quote">I had a similar problem, turned out to be the spark plugs. It was fouled and gapped wrong. Check to see if it's that.</TD></TR></TABLE>
Yea...check all your basics first....Plugs, Wires, etc...
ok, so i've tried replacing the fuel filter, spark plugs, and my wires, THE CAR STILL BOGS WTF.. and now when i turn it on the rpm's kinda begin to surge up and down... Someone Please help me out it would be greatly appreciated.
Re: (95d15red)
they have a tendency to work themselves loose...it's underneath your throttle body...actually made on to it....there is a plate that is held on by 2 screws, loosen those, take them out and see if the valve inside is loose...if so tighten it
latinracerct
10-19-2006 01:57 PM
