Winshield wSquirter problem!!! Help!!!
my windshilked squirteers stopped working out of nowwhere. i have not a clue why. i checked the fuse for the wipers, its ok, everything works except the squirters. any ideas??
Check your lines, and also if there's fluid in the reservoir. Do you hear a noise when you attempt to get fluid to squirt out?
maybe you need to get those LED squirters
really though....check the actual ports themselves.. and makes sure they are not pluged.. and check your fluid level...
put some distilled water in it and run the squiter motor.. make sure the motor is working
[Modified by Crazydave, 2:42 PM 2/12/2002]
The squirter jets themselves can clog over time.
If so, pull them off and soak in hot water/simple green solution for a while...
Don't worry, mine quite on me too.
I know the lines look terrible so I think I'll replace them while I'm at it. I just have to crack open the Helms to figure out how to reach the motor(s).
Get a thin metal wire (not an electircal wire with a rubber sleeve) and stick that in the hole on the washer nozzle jets, this should do the trick to unclog them (that's what we do at work). Later!
rsx03
Oct 12, 2002 10:41 AM
