raDIATOR ONLY SHOOTS OUT STEAM
Old Jun 21, 2005 | 08:54 PM
missionaryrider's Avatar
Default raDIATOR ONLY SHOOTS OUT STEAM
ok i dunno whats going on i put in my new motor and fill up the radiator and it just shoots out steam and it wont circulate i dunno what the problem is
Old Jun 21, 2005 | 09:00 PM
Kamin's Avatar
Default Re: raDIATOR ONLY SHOOTS OUT STEAM (missionaryrider)
did you bleed the cooling system when you swapped? replace the thermostat?
Old Jun 21, 2005 | 09:01 PM
i didnt drain it, it all came out when i rebuilt the motor and its stock thermostate
Old Jun 21, 2005 | 09:09 PM
Kamin's Avatar
Default Re: (missionaryrider)
when did i say anything about draining?
but since you brought it up, did you refill the radiator?
Old Jun 21, 2005 | 09:13 PM
yes
i cant figure out what it wouls just keep steaming. whould it get that hot if its not ricuculating?
Old Jun 21, 2005 | 09:19 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by missionaryrider &raquo;</TD></TR><TR><TD CLASS="quote">yes
i cant figure out what it wouls just keep steaming. whould it get that hot if its not ricuculating?</TD></TR></TABLE>
Abysmal spelling aside - I can stitch up the egregious wounds in the English language later - your radiator cap may be broken, your thermostat in backwards, a hose collapsed, your radiator damaged internally or a coolant passage blocked. Undo the bleeder screw on the upper water neck and let it idle. Also, put real coolant in it and run the car with the heat going full blast so no air pockets develop in the heater core.
ILcrxsi1
Mar 29, 2007 03:14 PM
EGdrop6
Jul 20, 2006 07:19 AM
slikz714
Jul 12, 2006 03:40 AM
tkHBseries
Feb 19, 2005 06:48 PM
EGh22aEG
Jan 9, 2002 06:37 PM
