Code 20, starter won't engage, and whats a ecu test harness?
Old Jun 21, 2005 | 04:57 PM
vtecn8ive's Avatar
Default Code 20, starter won't engage, and whats a ecu test harness?
Okay well I think I have posted 2-3 topics on this mini-me swap and I keep getting problems.
I am getting a code 20.
Just got done checking all the grounds nice and clean.
I cut all the wiring for the A/c but left the relay in.
I was also missing the wiring from the battery to the underdash fuse box so I hooked it up with some 16-18 gauge wiring...
... only thing I hooked it up where the alternator was suppose to be and I hooked up the alternator where the battery was suppose to be. I am going to change out the alternator right now and see if that fixes.
Also people said it could be the dizzy? I will take that apart also and take a look at it.
Any other pointers?
ALSO my starter will not engage when I turn the key to key lll (crank position). But if I put a jumper wire in there it will engage.
I made all the checks up to my next question..
Whats a ECU TEST HARNESS?
What does it look like?
Can I just make one?
Main Relay is clicking (so thats good)
Grounds are good, snipped wires are seperated and covered, main relay is clicking.
Help any input please.
-shane
Old Jun 21, 2005 | 05:20 PM
vtecn8ive's Avatar
Default Re: Code 20, starter won't engage, and whats a ecu test harness? (vtecn8ive)
I should also mention it is a 90 CRX Si with a d15b2 block with d16z6 cylinder head and intake manifold.
I am running it on a pm6 (uh the CRX Si ecu). I will be either installing a vtec controller or just a rpm activator.
-Shane
Old Jun 21, 2005 | 07:19 PM
vtecn8ive's Avatar
Is there a way to get around using the test harness?
Shane
Old Jun 21, 2005 | 07:36 PM
paulzy's Avatar
ummm...why were you hacking all these wires in the first place?
Old Jun 21, 2005 | 07:44 PM
vtecn8ive's Avatar
Default Re: (paul vang)
The only wires I touched. Are the following...
1. A/C wiring that runs along the front crossmember, kept the relay
*(because previous owner took out A/C stuff and some of the wiring had rubbed up on the exhaust manifold)
2. IAT sensor connector
*(was to short so I lengthened it)
3. Shoot its the one on the back of the intake manifold nearest the brake booster
*(was also to short)
4. Added battery wire to underdash fuse box
*(because I have no idea where the stock one was and I looked all over)
Thanks Paul for the reply... NOW HELP ME
-shane
Old Jun 21, 2005 | 08:30 PM
paulzy's Avatar
try that battery wire first....
what's code 20? I don't know codes off the top of my head
Old Jun 21, 2005 | 08:31 PM
JDMDC231's Avatar
Hmm so if i read this right car is not cranking right?? or it is cranking but not getting spark...
Well most of the time check the basic's geting a car started is not to hard all you really need is the basic's Spark, Compression,fuel, and timming if one of those is not working then you would mostly have to look at the one diagram...
But in your case which if you are not getting it to cracnk then on like a mini me setup like that i found that most of the wiring to disturbitor is not hooked properly
So what you would want to do is that run wire to wire.... note on older cars the white and yellow wire look simualr since being the age of the wiring but send me some more info on whats going on and i can basically fill in the blanks for you...
You might want to check the timing though since being that the Rex that we got from you the timing was off you want to line up the timing mark on the crank to the single white mark not the one thats in the middle of the two red and yellow i think.. but the one that is by itself which is color white okay....
Chao
Old Jun 21, 2005 | 08:36 PM
vtecn8ive's Avatar
oops.
Code 20 is ELD (electric load detected) or something like that.
What do you mean by check the battery wire? Which one? The one going to the fuse or the starter?
-Shane
Old Jun 21, 2005 | 08:40 PM
JDMDC231's Avatar
Default Re: (vtecn8ive)
Well ELD code means either there is a falt in the alt... or a short in the wires going to the alt itself but most times for older cars its alt. going bad.....
Old Jun 21, 2005 | 08:41 PM
vtecn8ive's Avatar
haha good to hear from you man. Hope the Rex is still running. hey I never touched that motor just got it in the car and running nothing more, nothing less.
It is not converted to obd1 it is just obd0 right now so I doubt it is the dizzy wires.
(its pretty much a d16a6 with vtec that is not hooked up yet )
The car will not crank. However if I put a jumper wire from the battery to the starter then it will crank over. Then I checked the ignition switch and it says there is continuity between all of the necessary connections.
My next step was to check the 3p in the underdash fuse box for voltage. Which I did and my next step is the ecu Test harness which I don't have the money for so I am seeing if there is a way around it.
-Shane
Old Jun 21, 2005 | 08:47 PM
vtecn8ive's Avatar
Changed out the alternator and same problem.
Something had to have gone wrong cause when I open my doors the engine light and **** go on. When I close it they go off. When I step on the brake its like all my engine lights **** goes on again.
Dang this is the same wiring harness just a different motor I don't get it!!!
Old Jun 21, 2005 | 09:21 PM
blah13's Avatar
When I did my dohc swap I got this code, my door light woudl stay halfway on all the time too. Never fixed it, now after putting in the sohc in my dx I got the code again, annoying as hell. Though both times it hasnt caused my car to not start, I'd look elsewhere for the starting problem than the code 20.
Old Jun 21, 2005 | 09:39 PM
imoua's Avatar
Default Re: (blah13)
ELD is located on your fusebox under the hood...
Old Jun 22, 2005 | 03:36 AM
vtecn8ive's Avatar
Default Re: (imoua)
Really? Where at?
Old Jun 22, 2005 | 12:20 PM
imoua's Avatar
Talking bout ELD, today I went out to start my crx and it didn't start.. had that stupid code 20 too.. But got it fixed.. Anyways, I think it's the 4wire plug in the fusebox.. they are probably loose and don't have a good connection, so try to push them back into place.. If this don't work, you might need a new fusebox..
Old Jun 22, 2005 | 01:10 PM
vtecn8ive's Avatar
Default Re: (imoua)
Yeah I am going to put a different fuse box in it right now!!! (crosses fingers) hopefully it fixes this ****!!!
-Shane
Old Jun 22, 2005 | 01:54 PM
vtecn8ive's Avatar
yeah that didn't work . Back to diagnosing
Any other thoughts at what it could be?
Things that have been done..
1. Clean grounds
2. Changed Alternators
3. Changed fuse box
How would I see if the alternator wiring was at fault?
-Shane
Old Jun 22, 2005 | 08:02 PM
vtecn8ive's Avatar
bump
Daniel99
Jul 10, 2018 05:45 AM
dbb95ex
K Series
Jan 8, 2014 06:59 PM
j4s0n1337
Apr 15, 2011 09:41 AM
nickeynick
17
Feb 2, 2011 11:02 AM
