trouble starting when hot
Old Jun 21, 2005 | 06:28 AM
eg4door's Avatar
Default trouble starting when hot
my car has trouble starting when it is hot only once in a while. Sometimes when it is parked in the sun all day it won't start, I'll wait a minute and then it will start. Also when I drive and turn it off for a few minutes it will do it. Now this will only happen a couple times a week so not everyday. Any ideas? There is no check engine
Old Jun 21, 2005 | 09:38 AM
boostmyda's Avatar
Default Re: trouble starting when hot (eg4door)
both of my hondas have done that
and my friends did it..
i think its just a honda thing.. i have heard its the starter and i have heard its some relay..
as long as it eventually starts its ok
Old Jun 21, 2005 | 10:06 AM
d_mina's Avatar
Try another distributor... Your ignitor coil could be going out
Old Jun 21, 2005 | 04:19 PM
eg4door's Avatar
Default Re: trouble starting when hot (teameracer3)
my starter, coil and iginitor are all new. I think its some senser but I'm not sure witch one it could be. It usually only happens on really warm days.
Old Jun 21, 2005 | 04:31 PM
CardDealer's Avatar
Banned
Modified by CardDealer at 4:51 PM 11/16/2006
Old Jun 21, 2005 | 04:48 PM
neutron91's Avatar
Default Re: trouble starting when hot (schlit)
100% sure its the main relay... has happened to every honda i have owned
Old Jun 21, 2005 | 04:54 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit &raquo;</TD></TR><TR><TD CLASS="quote">That is a symptom of a bad main relay. I've had and fixed this problem. When it's hot, the solder connections in the relay crack open and the relay malfunctions. As it cools down, the relay works again. Do this check, when you have trouble: turn your key to the ON position (not start) and immediately listen for the fuel pump priming 3-seconds or so. It's kind of a humming sound coming from the rear of the car (fuel pump is in the gas tank). If it doesnt prime, its your main relay. The car should be able to turn over but not start.
This is a common problem on Hondas, but you shouldnt live with it because it can strand you.</TD></TR></TABLE>
Yes. This happened on my brothers DA. It is a known problem. Try replacing the main relay.
Old Jun 21, 2005 | 07:38 PM
eg4door's Avatar
Default Re: trouble starting when hot (JDM-EJ1)
OK thanks I'll try the main relay. I'm sure the pump was turning on but I'll try a new relay an see if it happens again.
Old Jun 21, 2005 | 08:40 PM
Backk InTheDA's Avatar
I hate everything
That would be a main relay, my DA does it, when the interior gets to warm, it wont connect when you try and crank it over, well it will, it just wont last, thus, the car will die.
Usuaslly happens after filling up, best way to avoid this is to drive w/ your interior fan off, or if you know you gotta start your car, while only letting it sit 5-10 minutes, crack a window, or when you get to your car, open the doors for a sec and let it air out.
Good luck
Old Jun 21, 2005 | 10:24 PM
coupe_hybrid's Avatar
Default Re: trouble starting when hot (iTR2The3rdGen)
It's your fuel relay it's located right by the fusebox by the drivers side.
Old Jun 21, 2005 | 10:28 PM
eg4door's Avatar
Default Re: trouble starting when hot (coupe_hybrid)
so should I change the fuel or main relay?
Old Jun 21, 2005 | 10:37 PM
Jimmy's Avatar
Global Moderator
Been there, done that.
It's your PGM-FI main relay.. controlls weither or not your fuel pump primes or not.
The joints in the relay crack and have loose/bad connections and cause this to happen..
Easy simple $10.00 fix
http://www.markl.f9.co.uk/howt...y.htm
http://autorepair.about.com/cs...1.htm
Need help or questions,pm me.
Old Jun 22, 2005 | 03:07 AM
CardDealer's Avatar
Banned
Default Re: trouble starting when hot (Jimmy)
Old Jun 22, 2005 | 03:37 AM
neutron91's Avatar
fuel/main relay = same thing
Old Jun 22, 2005 | 01:12 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit &raquo;</TD></TR><TR><TD CLASS="quote">Never heard of a fuel relay.....</TD></TR></TABLE>
Well then you must never read.
Old Jun 22, 2005 | 02:37 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
main relay for sure BTW hodna main relays are dual relays... The first relay powers up the computer and supplies power for the second relay. Once the computer is powered up, it will ground the second relay, which supplies power to the fuel pump.
Old Jun 22, 2005 | 03:50 PM
Bond's Avatar
Default Re: trouble starting when hot (BrokeAssPinoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy &raquo;</TD></TR><TR><TD CLASS="quote">main relay for sure BTW hodna main relays are dual relays... The first relay powers up the computer and supplies power for the second relay. Once the computer is powered up, it will ground the second relay, which supplies power to the fuel pump. </TD></TR></TABLE>
Oh yeah! Someone that actually knows what they are talking about .
Old Jun 22, 2005 | 04:09 PM
Crasian's Avatar
[QUOTE=Jimmy]Been there, done that.
[QUOTE]
or free if u just solder it again
DaiSeeFut
Oct 31, 2012 04:51 PM
benwadb1
Sep 14, 2008 05:31 PM
progress
28
Jan 15, 2007 10:42 AM
HCJDM1
Sep 7, 2006 04:54 PM
Chief Brody
Honda Motorcycles
Jul 24, 2003 10:51 PM
