window problem!
tthanks a lot for checking this out! i have a problem with my window on the drivers side.
The bracket that holds the window glass in place at the bottom of it has become loose. now my problem is that there was some type of glue that had hold the glass window and the bracket together, it fell out when my car was too bumpy. i was wondering what kind of glue is needed to help hold it in place because i used this cheap glue called Expoxy or something like that and it didnt hold. I need a stronger type of glue that will lock and have a secure hold. any info or so will help me out a lot. this is for a 92 4dr civic. again thanks a lot!
tomy_r
tomy_r
any pics of the problem? i am lost by just reading it. I have problems with my dirvers side too but mine is a 98 ex. Year, model of car?? my window stops rolling too but a simple adjustment works fine for me. Pain in the behind but it works. more info and pics please.
i got a four-dour civic year 92 LX with power windows. the problem is being solved right now because i called up a auto glass company and they told me that i should use the glue EXpoxy that i had bought earlier. they say it should take 2-3 days at max or something like that.the problem is that the bracket that hold the window to the frame is loose. this bracket is that holds the window and it together is by some type of glue! know what am i saying? the glue hold the bracket and glass together! sorry about the confusion but i cant seem get this in time so i have to explain it! anyways thanks fo the response!
tomy_r
tomy_r
lol i am sure that it is. i dont really like gluing stuff together. just adjust it, grease the bottom of the window brackett (where the window stops and the rolors are supported). i greased mine up and works as new and smoother than new!!! hahah...good luck and have fun taking out your side panel!!
man, on my 96ex both the drivers and passengers windows are constantly slipping out. especially when it rains. i think its a diff problem though, the bolts in the bottom corner of the door come loose, the track moves back and the window falls out. pain in the *** having to re-tighten the 'track bolts' every couple months.
Shushiplease
Jun 25, 2008 05:12 AM
KEVlN
11
Nov 11, 2005 08:36 PM
asianspec
Jan 7, 2005 11:22 AM
