99 Honda Civic Halo Headlight/Taillight Install Questions
Ok, so I've go a set of Halo Head lights and Tail lights. The headlights have a black wire ( ground) and red ( power ). What and where should I hook the power in to? Same thing with the Taillights I've got a green ( i guess that is ground) and a red ( power ) what and where should I hook the power in to?
the power would go in the red i would think
the black/green would be ground
when you remove the stock headlights it should be easy to determine what wires go where
hook the wires up to the power and ground of your running lights on the blinkers (front) and to the tail lights (not brake) in the rear that way they come on with out the headlight coming on , looks cool
The headlights should be obvious. Since they are Halos you'll want to ground the black/green wire somewhere on your chassi, and then run the positive to a power source (splice it in with your turn signal, battery, etc).
Same thing for the tail lights. Ground the green, and find a power source for the halos.
RPMvulocity
Mar 28, 2005 08:56 AM
beginnerCivic
Audio / Security / Video
Sep 9, 2003 05:10 AM
