adjusting valves ?
Old Jun 20, 2005 | 05:40 PM
93slmdcvcsi's Avatar
Default adjusting valves ?
on a B18C1 or any B-series motor, Isn't there a certain order that this has to be done?
Old Jun 20, 2005 | 06:41 PM
sporkcrx's Avatar
Default Re: adjusting valves ? (93slmdcvcsi)
You do each cylinder when it's at TDC, so 1-3-4-2. It's a quarter turn of the cam gear or a half turn of the crank pulley to go to the next TDC for the firing order.
There's a trick to do it in half the time, but I'm trying not to confuse you. Do it when the engine is cold. And if you dont' have any clue what the above paragraph means, I wouldn't risk it and just take it to someone who knows what they'd be doing.
Old Jun 20, 2005 | 07:00 PM
Default Re: adjusting valves ? (sporkcrx)
well I have done it before, but it has been a while and i cant remember the shortcut. try to explain it and i am sure that i will remember
Old Jun 20, 2005 | 07:37 PM
Suck my DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">You do each cylinder when it's at TDC, so 1-3-4-2. It's a quarter turn of the cam gear or a half turn of the crank pulley to go to the next TDC for the firing order.
its not really a trick u just have to do it when the motor is cold..or less than 100 degrees i believe...they say do the exhuat ones first but i dont know if that is really a must
Old Jun 20, 2005 | 08:36 PM
sporkcrx's Avatar
Default Re: adjusting valves ? (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">
its not really a trick u just have to do it when the motor is cold..or less than 100 degrees i believe...they say do the exhuat ones first but i dont know if that is really a must</TD></TR></TABLE>
That's not the trick, the trick is being able to do 1 full cylinder, 1 in., 1 ex., rotate engine, 1 full cylinder, other in., other ex. This gets it done in half the time. In 3 hours I can post up how to do it, I have it written down at home.
As for the original poster, here's a walk thru:
http://www.c-speedracing.com/h...t.php
Old Jun 20, 2005 | 09:06 PM
Suck my DX's Avatar
[QUOTE=sporkcrx]
QUOTE]
thats the only way i know how to do it...whats the longer way?
Old Jun 20, 2005 | 09:18 PM
sporkcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">[
thats the only way i know how to do it...whats the longer way?</TD></TR></TABLE>
Doing each cylinder indevidually
Old Jun 20, 2005 | 10:08 PM
snowseeker's Avatar
lol
Old Jun 20, 2005 | 11:33 PM
sporkcrx's Avatar
Alright here we are.
With #1 at TDC, adjust both intake and exhaust on 1, intake on 2, exhaust on 3.
Adjust to #4 at TDC, adjust both intake and exhaust on 4, intake on 3, exhaust on 2.
Old Jun 21, 2005 | 02:39 AM
Thanks man, i appreciate it!
nemesis25
Dec 30, 2007 03:23 PM
houstondigital
Aug 10, 2005 12:26 PM
silentblackhat
Dec 26, 2004 09:49 PM
T--Rex
Oct 21, 2004 05:49 PM
endlessdv
May 15, 2004 06:50 AM
