Somone find my problem !!!! 22 VTEC pressure valve
Old Jun 20, 2005 | 04:20 PM
theEGkid's Avatar
Default Somone find my problem !!!! 22 VTEC pressure valve
I have a 92 hatch with an ls vtec (p72) gsr head. For some reason my v-tec clicks when activating and sometimes feels like it not on. i started popping a 22 so i put in a type r oil pump with a spring shim for added pressure. all seemed fine for a day or to until today when i romped it on the highway i threw a code 22 again. Why does this keep happening? Would the port size on my oil fittings be to small?Perhaps theres blockage somewhere.someone help me out.
Old Jun 20, 2005 | 04:57 PM
Echo7847's Avatar
Default Re: Somone find my problem !!!! 22 VTEC pressure valve (SmoothlilHatch)
22 is vtec oil pressure switch. Either you've got a faulty switch or a fault in the wiring.
Old Jun 20, 2005 | 07:50 PM
theEGkid's Avatar
It sounds like lack of pressure. why would wiring mess with the way v tec engages. it seems like its more mechanical
Old Jun 20, 2005 | 07:53 PM
tsjeff's Avatar
Default Re: (SmoothlilHatch)
is there enough oil?
Old Jun 20, 2005 | 08:50 PM
nub.96ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmoothlilHatch &raquo;</TD></TR><TR><TD CLASS="quote">It sounds like lack of pressure. why would wiring mess with the way v tec engages. it seems like its more mechanical</TD></TR></TABLE>
If the wiring is messed up somewhere along the way it may not be getting the signal to the ECU to engauge the VTEC components. I had the same problem but it was the pin that I added into the ECU plug, it was loose and whenever anyone bumped my ECU w/ their foot I got a CEL 22. Sometimes it would just throw the code for no reason.
Old Jun 21, 2005 | 11:19 AM
theEGkid's Avatar
my v-tec engages fine. its not wiring. just for some reason it started to pop a 22. i put the new pump in and it does the same thing. my v-tec makes a clicking noice when it engages. sounds like the pins locking. anyone know what thats all about?
Old Jun 21, 2005 | 02:24 PM
b18cKoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [b]9 3 d e l[QUOTE=nub.96ek[/b] &raquo;</TD></TR><TR><TD CLASS="quote">
If the wiring is messed up somewhere along the way it may not be getting the signal to the ECU to engauge the VTEC components. I had the same problem but it was the pin that I added into the ECU plug, it was loose and whenever anyone bumped my ECU w/ their foot I got a CEL 22. Sometimes it would just throw the code for no reason.</TD></TR></TABLE>
Winner
Old Jun 21, 2005 | 03:07 PM
Relic1's Avatar
Check the pin first, that sounds like a good chance it's right.
But it doesn't have to be electrical, I used to get a click sound like this.
Turned out I was a little low on oil. After an oil change everything was back to normal.
LS w/GSR head. how did you route oil to the head?
if there is just enough pressure... at higher R's it would work fine, but at lower R's it may see low pressure and set the code.
It could also be that sensor messing with you.
Old Jun 23, 2005 | 09:12 AM
theEGkid's Avatar
im gonna swap solenoids
Old Jun 25, 2005 | 07:54 AM
theEGkid's Avatar
Hey i got a question. since i have an ls v-tec should i be running 4 1/2 quarts of oil for vtec. cause i think the ls only takes 4. that could be causing my problem. this thing loves drinking oil
Old Jun 27, 2005 | 05:26 PM
theEGkid's Avatar
alright i checked the v tec pressure today and its only around 39-45 psi at 6000k. Somethings not right. i have the oil line tapped off the oil pressure switch. with 4-an line. maby its not enough?
Ready to shoot this car!
Old Jun 27, 2005 | 07:17 PM
neutron91's Avatar
might wanna take the solenoid off and clean the screens off with some brake cleaner... they can get blocked by built up oil/sludge and not allow the right pressure to flow... this happened to my car and it threw a cel for the oil pressure switch... cleaned it up popped it back on and all was well
missionaryrider
Dec 9, 2007 01:50 AM
eat_sleep_ej1
12
Dec 1, 2007 04:43 AM
4door hobo
Jul 30, 2007 07:53 PM
4door hobo
HatchBox
40
Nov 23, 2003 05:22 PM
