CAR SPUTTERS...HELP!
I am in the same boat you are in. Check out my thread and you might find something that will help: https://honda-tech.com/zerothread?id=1258804
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tdawg1030 »</TD></TR><TR><TD CLASS="quote">so what do i do with the IAC, and what is it really?? also i switched from 87 octane to 92 octane because im about to turbo it. could that be it?</TD></TR></TABLE>
The IACV comes to play when your car is at normal operating temp. It controls the idle at regular temp operation. It uses coolent temp to control air flow at idle. You can clean it if you want, but it didn't help my problem. PM me if you have any more questions
I wouldn't put 92 octane gas into your car until you get your turbo installed onto your car...the hole idea of higher octane fuel with your turbo is to eliminate detonation.
sonson6
Feb 22, 2008 12:48 AM
mikeunreal
12
Oct 25, 2005 08:14 AM
