Short Blocks: D16a6 VS D16y8! Which to use for Turbo build.
Old Jun 17, 2005 | 07:12 PM
Darkane's Avatar
Default Short Blocks: D16a6 VS D16y8! Which to use for Turbo build.
Hey, my question for ya guys is which block should I use and why? I know the a6 has Steel mains and is a little stronger, but I think the y8 has a better oil pump stock. Let me know guys and I got both blocks already just trying to choose which to go with. ALSO... Side question I might do a Vtec head on the blocks as well, does anyone have a Compression figure for an a6 with z6 head and Vitaras? or the y8 with z6 head and Vitaras? Also Stock head gasket.
Thx all.
EDIT: just realized the compression would be the same in both blocks so just need the one figure.
Old Jun 17, 2005 | 07:24 PM
Ignitecivic's Avatar
Default Re: Short Blocks: D16a6 VS D16y8! Which to use for Turbo build. (Darkane)
a6 block, with z6/y8 head gasket and z6 head without the vitaras 10:4
Old Jun 17, 2005 | 07:39 PM
Darkane's Avatar
Default Re: Short Blocks: D16a6 VS D16y8! Which to use for Turbo build. (Ignitecivic)
Hmm ok, I *think* the vitaras only drop the CR on the stock y8 and y7 about .5 so I Assume about 9.9CR for a turbo setup... Still alittle low but I will make much better power on lower boost VS non-vtec and lower CR and higher boost.
Old Jun 17, 2005 | 08:44 PM
swifty4u's Avatar
My friend has an a6 block, z6 head, with vitaras and he told me he is somewhere in the low 9's for the CR.
Old Jun 18, 2005 | 05:09 PM
Darkane's Avatar
Default Re: Short Blocks: D16a6 VS D16y8! Which to use for Turbo build. (swifty4u)
Ah I see.. hmm ok that should be perfect then. Does he have a turbo setup on it? And if so what are his numbers? Thx.
Old Jun 18, 2005 | 05:13 PM
Revolver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ignitecivic &raquo;</TD></TR><TR><TD CLASS="quote">a6 block, with z6/y8 head gasket and z6 head without the vitaras</TD></TR></TABLE>
Old Jun 18, 2005 | 05:26 PM
swifty4u's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darkane &raquo;</TD></TR><TR><TD CLASS="quote">Ah I see.. hmm ok that should be perfect then. Does he have a turbo setup on it? And if so what are his numbers? Thx.</TD></TR></TABLE>
Yea, his is turbo. No numbers as of yet becaue he is still tuning it himself..but at 12 lbs he is beating mid-low 13 second cars and this is in an ef. He also has rods, a block guard, head work and a huge turbo though.
Old Jun 18, 2005 | 05:34 PM
Darkane's Avatar
Nice. Im going Eagle/Scat rods, Vitaras, Block posting/guard, and maybe a port and polish on the Z6 head. Next year when budget permits Custom turbo kit.
Old Jun 18, 2005 | 05:42 PM
swifty4u's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darkane &raquo;</TD></TR><TR><TD CLASS="quote">Nice. Im going Eagle/Scat rods, Vitaras, Block posting/guard, and maybe a port and polish on the Z6 head. Next year when budget permits Custom turbo kit. </TD></TR></TABLE>
My friend waited a while for boost too. He built everything, then drove the car as a winter car because 1) he has an s2k and 2) to break it in so he doesn't have to wait for boost.
Minime515
Apr 24, 2018 09:52 PM
style'n_DC2
Jan 17, 2009 12:33 AM
egturbo
Jun 14, 2004 04:05 PM
milruner
Dec 29, 2003 07:13 AM
Red_Si
Jul 4, 2002 12:07 AM
