Timing Question PLease Help
Old Jun 17, 2005 | 04:46 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Timing Question PLease Help
I read posions faq on timing belt on his mom's z6.
My question is this.
Before I pulled off the crank, I used whiteout and made sure that I aligned everything before I put the crank back on.
However, now that I put the crank on and like up the TDC on the top cam gear with the marks on the plastic, BTW I never took off the cam gear, my timing seems off.
I have rotated it a few times and it seems smooth, and fine.
Anyway to verify my timing is right.
Also on the crank there is 2 lines, and then 3 lines later, where should the marking line up on?
I mean, I had an allen key holding the flywheel during all of this, so I know it definately didn't move.
Also I have a theory, how can i mess up the timing, if the crank never moved since it was held by the allen key holding the flywheel.
Old Jun 17, 2005 | 04:59 PM
MugenHonda's Avatar
Default Re: Timing Question PLease Help (MugenHonda)
ttt
Old Jun 17, 2005 | 05:19 PM
JCracer723's Avatar
u have to line everything with the white line on the crank pulley..
where is not lining up? are the 2 lines on the cam gear linning to the marks on the plastic cover?
logg in to AIM
civiccoupe94
Jan 11, 2008 07:08 AM
kixcrx
Sep 11, 2007 01:35 AM
Project_CD5
Jul 25, 2007 03:20 AM
SOHC_MShue
Apr 20, 2005 09:31 AM
Kirt Porter
Oct 8, 2004 09:10 PM
