About axles
Old Jun 16, 2005 | 10:11 PM
marc-111's Avatar
Default About axles
is the GSR B18C axles the same with the B16a? or they have a different size?
thanks!
keaps206's Avatar
same
Old Jun 16, 2005 | 10:12 PM
marc-111's Avatar
Default Re: (keaps206)
size and everything the same? for a hydro tranny
Old Jun 16, 2005 | 10:21 PM
keaps206's Avatar
pretty sure
marc-111's Avatar
thanks!
Old Jun 17, 2005 | 05:41 AM
marc-111's Avatar
bump
Old Jun 17, 2005 | 06:57 AM
marc-111's Avatar
no other comments?
Old Jun 17, 2005 | 07:01 AM
solareclipseauto's Avatar
Default Re: (marc-111)
drivers side is different because they both use different intermediate shafts. the gsr intermediate shaft has a male end where the axle goes into and the b16a shaft is female where the axle goes into
Old Jun 17, 2005 | 07:03 AM
marc-111's Avatar
Default Re: (solareclipseauto)
how about the passenger side?
Old Jun 17, 2005 | 07:05 AM
passenger side you can use either or but also make sure if you have abs you have abs axles
Old Jun 17, 2005 | 07:08 AM
marc-111's Avatar
what does that look like? you have picture? for what to look at?
Old Jun 17, 2005 | 07:25 AM
neutron91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solareclipseauto &raquo;</TD></TR><TR><TD CLASS="quote">drivers side is different because they both use different intermediate shafts. the gsr intermediate shaft has a male end where the axle goes into and the b16a shaft is female where the axle goes into</TD></TR></TABLE>
this is true for the obd0 b16a... the b16a2 and a3 axles will work on the drivers side with the 94 up gsr intermediate shaft
Old Jun 17, 2005 | 07:39 AM
marc-111's Avatar
Default Re: (neutron91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 &raquo;</TD></TR><TR><TD CLASS="quote">
this is true for the obd0 b16a... the b16a2 and a3 axles will work on the drivers side with the 94 up gsr intermediate shaft</TD></TR></TABLE>
Old Jun 18, 2005 | 01:00 PM
marc-111's Avatar
does it matter if a buy a axle with abs or i should buy the one without abs?
Old Jun 18, 2005 | 05:13 PM
neutron91's Avatar
the splines are the same... only difference i know of is the abs one has a ring on it for the wheel sensors... if your car has abs then yes you should get the corresponding axle... if you dont have abs then it doesnt matter
Old Jun 18, 2005 | 05:31 PM
marc-111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 &raquo;</TD></TR><TR><TD CLASS="quote">the splines are the same... only difference i know of is the abs one has a ring on it for the wheel sensors... if your car has abs then yes you should get the corresponding axle... if you dont have abs then it doesnt matter</TD></TR></TABLE>
got it thanks!
Old Jun 18, 2005 | 10:08 PM
98b18black's Avatar
Yea...if you dont have abs and get the axles with abs you can just knock the abs ring off...
JDM***CD6
Apr 8, 2011 12:19 AM
wrenchez81
12
Aug 8, 2009 01:17 PM
blackmfoggie
Jul 18, 2008 01:47 AM
RanCRX
20
Oct 23, 2007 12:47 PM
7PSiEF9ZC
Aug 15, 2003 02:23 PM
