attn glen or yoshi..need help on japanese to english translation. (oil-cooler instruction)
the pic pretty much says it all, but then again maybe not. its an oil to water cooler. can you help me and translate the directions into english text? thanks.
why do j00 guys buy parts that have instructions j00 can't read? j/k
1. remove the engine under cover
2. drain coolant
3. drain engine oil
4. remove oil filter
5. remove the oil filter union(?)
6. attach the union nut to the union w/ along w/ some oil (torque to 30N/m)
7. apply some oil to the oil filter's O ring. Attach the oil filter to the union bolt (torque to 78.5N/m)
8. remove the coolant cap on the engine block
9. facing the figure at left, attach hose #4 and secure it w/ hose band #5
10. fill w/ oil
11. fill w/ c00lant (make sure to remove any air bubbles)
12. check for any leaks
13. replace the engine under cover
y
shi - whose sad he couldn't work for the UN
2. drain coolant
3. drain engine oil
10. fill w/ oil
y
Yes, I concur with Yoshi. (To the best of my reading ability. Never seen so many "torihazusu" / "toritsukeru" in one place.)
jimmy193
Aug 17, 2008 02:29 AM
BlueShadow
Aug 24, 2005 06:52 AM
