removing antenna 93 del sol
Old Jun 16, 2005 | 07:40 AM
nrgone's Avatar
Default removing antenna 93 del sol
so i was planning to remove my antenna, gotta get it from the trunk, then i find out theres this clear plastic tubing[whats that stuff?], like if the trunk was hooked up to an iv or something. i removed the lil metal piece from the outside. do i just yank it out of there?
Old Jun 16, 2005 | 08:14 AM
Del Sol SiR's Avatar
Default Re: removing antenna 93 del sol (nrgone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nrgone &raquo;</TD></TR><TR><TD CLASS="quote">so i was planning to remove my antenna, gotta get it from the trunk, then i find out theres this clear plastic tubing[whats that stuff?], like if the trunk was hooked up to an iv or something. i removed the lil metal piece from the outside. do i just yank it out of there?</TD></TR></TABLE>
Thats sounds like a drain tube...
74502-SR2-000 TUBE ASSY., DRAIN (UPPER)
74505-SR2-000 TUBE ASSY., DRAIN (LOWER)
I wouldn't remove it...
Old Jun 17, 2005 | 09:33 AM
nrgone's Avatar
how would i remove the antenna? still having problems. since theres rust around it and i dont even listen to the radio. need help.
Old Jun 17, 2005 | 11:22 AM
idriveadelsol7's Avatar
Default Re: (nrgone)
gut the car on the passenger side (trunk and interior) unscrew everyting linked to the antenna.
then on the outside of the vehicle, you need to twist the metalic thing with 2 groves on it. it's pretty simple. but my explaination sucks ***.
[-(antenna)-]
- = groves
hope i could be of some assistance.
Old Jun 17, 2005 | 06:06 PM
nrgone's Avatar
ty works
Old Jun 17, 2005 | 07:17 PM
nocturnaldragon's Avatar
ok you take off the nut on the outside of the car, that holds the antena to the retainer on the body.
Then on the interior theres a bolt that holds a metal clamp to the antena to losen it from the chassis, You may want to remove that bracket completly if you chose. Its simply bolted on.
Remove the antena wire and pull the sucker out of there with the tub attached. Its just a drain tube nothing special.
Nave43
Aug 21, 2017 11:24 AM
postman
Jul 1, 2007 09:12 AM
bryphotoguy
Jul 9, 2006 02:06 PM
yellowmonkeyboy
Feb 14, 2006 02:22 AM
Del_Sol_s
Jul 1, 2005 08:07 AM
