Failed BAR, Valve cover air tube? Where do the coolant hoses go?
Old Jun 15, 2005 | 11:02 PM
92b18cx's Avatar
Default Failed BAR, Valve cover air tube? Where do the coolant hoses go?
Hey guys I failed BAR inspection because I didn't have the valve cover air tube hooked up, the one that flows from the valve cover back into the intake arm, I have it now but where do the coolant lines hook up? the ones that run along side the air tube? engine is an obd 1 gsr in a 92 cx, can anyone help me with this?
Old Jun 16, 2005 | 07:44 AM
IVI's Avatar
IVI
Default Re: Failed BAR, Valve cover air tube? Where do the coolant hoses go? (92b18cx)
should run into the throttle body to warm the butterfly in cold climates.
its not required really, im surprised they would fail you for that.
Old Jun 16, 2005 | 07:51 AM
MAV3RiCK478's Avatar
Default Re: Failed BAR, Valve cover air tube? Where do the coolant hoses go? (IVI)
in CA emissions is very strict. if any emissions eqiupment isnt hooked up they'll fail you on visual, especially if you're trying to get a swap BAR'd.
Old Jun 16, 2005 | 08:37 AM
B_CRUZ!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">should run into the throttle body to warm the butterfly in cold climates.
</TD></TR></TABLE>actually wrong. it does not connect to the throttle body at all. the hose you are talking about is one of the 2 hoses that run from the bottom of the intake manifold.
you need to use the oem metal piece with the rubber hoses on the end. The metal section is actually 2 hoses fused together. The lower of the 2 hoses has coolant that runs through it. Follow the line to see exactly where it is supposed to go. Honda designed that tube to be heated by the coolant for a reason.
Old Jun 16, 2005 | 05:01 PM
IVI's Avatar
IVI
Default Re: Failed BAR, Valve cover air tube? Where do the coolant hoses go? (B_CRUZ)
[QUOTE=B_CRUZ]actually wrong. it does not connect to the throttle body at all. the hose you are talking about is one of the 2 hoses that run from the bottom of the intake manifold.
[QUOTE]
well, that is how it is on mine. the way i understood it is that a coolant line from the IM goes directly to the throttle body to warm the butterfly to prevent it from freezing shut in cold climates. Here is a pic to show what i was referring to:
(i marked in white the one you need)
let me know if you need clearer pics i can remove my intake arm.
Old Jun 16, 2005 | 07:20 PM
92b18cx's Avatar
thanks for the pic, really helps alot. I should be able to figure it out now, I'll let you know if I need the other pic, probably will do this tonight in the garage.
Looks like maybe next week I can try the BAR again, cross your fingers....
Old Jun 16, 2005 | 07:24 PM
B_CRUZ!'s Avatar
doesn't look like a b18c1 is it?
just checked my helms and that isn't a GS-R throttle body nor is that a GS-R motor.
I reff'd mines and hooked everything up the OEM way.
Modified by B_CRUZ at 8:36 PM 6/16/2005
Old Jun 16, 2005 | 07:52 PM
B_CRUZ!'s Avatar
the bottom hose on your t/b is supposed to be hooked up to the IACV behind the manifold.
for the original poster. there is a little outlet for the metal hose on the thermostat housing.
right click and save this picture. blow it up. look closely at how it is connected. one side of the tube goes to the valve cover the other end of that goes to the intake.
for the coolant part, one tube connects to a little housing in the thermostat housing. the other end runs all the way to the front of the upper radiator hose outlet.
wasanissanFL
Oct 4, 2015 03:11 PM
MalcolmV8
Dec 12, 2011 01:55 PM
dannyly17
Jan 14, 2011 08:20 AM
Mullen
Aug 3, 2010 10:52 AM
JDM95lude
Mar 26, 2006 11:11 AM
