Help LS/Vtec Parts list?
If you haven't found the answers to your LS/VTEC question, here it is:
1. DOHC B-series cylinder head COMPLETE with valve cover, intake manifold, VTEC solenoid assembly and internals.
2. VTEC ECU.
3. VTEC B-series distributor.
4. 1990-2001 Integra LS head gasket.
5. 1994-2001 Integra GSR head bolts. This also includes ITR, Del Sol VTEC, and Civic Si.
6. 1994-2001 Integra GSR water pump. This also includes ITR, Del Sol VTEC, and Civic Si.
7. 1994-2001 Integra GSR timing belt or ITR timing belt.
8. 1994-2001 Integra GSR knock sensor. This also includes ITR, Del Sol VTEC, and Civic Si.
9. -4 steel braided hose with female ends (22 inches in length).
10. 1/8 inch NPT female to 1/8 inch NPT female to 1/8 inch BSPT male on run pipe tee.
11. 1/8 inch NPT male to -4 male straight adapter.
12. 3/8 inch NPT male to -4 male straight adapter.
13. 1/8 inch internal pipe plug.
14. 1/8 inch NPT pipe tap.
15. 3/8 inch NPT pipe tap.
16. 14mm drill bit.
17. 10.9mm drill bit.
18. 12mm X 1.25 mm tap.
2. VTEC ECU.
16. 14mm drill bit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ernald711 »</TD></TR><TR><TD CLASS="quote">good list
fellow LS/Vtecer here!!1</TD></TR></TABLE>
^ LS/V.
fellow LS/Vtecer here!!1</TD></TR></TABLE>^ LS/V.
JDMbull
Nov 8, 2006 12:49 PM
