New clutch not engaging after 6 months. HELP!
Old Jun 15, 2005 | 08:19 PM
spidermancivic's Avatar
Default New clutch not engaging after 6 months. HELP!
i swapped the tranny and clutch 6 months ago with a clutchmaster 3 kit on my 99 si.
this morning, i had to rev the car to 2500 rpms just to get get to go in first gear. now while i was driving, i cant get it to move in gear anymore. the engine runs, i stick it in first gear and give it some gas while releasing the clutch and it goes no where. i tried it in all the gears including reverse, and it goes no where. starting the car and throwing it in first gear, when i release the clutch it doesnt jerk and die like its supposed to.
now the clutch, flywheel, pressure plate is only 6 months old. the tranny i got was from a hydro jdm b16 sir2. the only thing i can think of is the clucth, but its only 6 months.
help!
Old Jun 16, 2005 | 08:23 AM
DARTin`'s Avatar
Default Re: New clutch not engaging after 6 months. HELP! (spidermancivic)
gl bump
Old Jun 16, 2005 | 09:17 AM
Default Re: New clutch not engaging after 6 months. HELP! (superblue)
Old Jun 16, 2005 | 10:15 AM
msmotorsports's Avatar
Clutch disc sounds like it broke. Take it apart and asses the damage.
Old Jun 16, 2005 | 10:25 AM
Default Re: New clutch not engaging after 6 months. HELP! (msmotorsports)
if it is the clucth disc, would i be able to put a stock clutch on the xtreme pressure plate that came with the clutchmaster3?
Old Jun 16, 2005 | 10:36 AM
Yes
Old Jun 16, 2005 | 10:38 AM
If you decide to go back to the stock disc be sure not to be too agressive with it or the same thing will happen. IMO I think the Xtreme pressure plates are a bit too extreme for daily driving. Might want to consider a less agressive setup.
Old Jun 24, 2005 | 06:34 PM
tranny,clutch pressure plate, fork, throwout bearing, and flywheel is out. lines and everything looks fine. no warpage. no oil leaks. only thing i can find wrong is that one of the springs in the clutch is loose. i can rock it back and forth with my fingers. it doesnt move when i shake the whole clucth disc though. can this be the cause of not causing my clutch not to engage?
Old Jun 25, 2005 | 08:51 PM
D@nnY's Avatar
the spring shouldnt be loose and sometimes a piece of the disk around the spring will break off and go in to the pressure plate....
Old Jun 29, 2005 | 11:02 PM
swapped with an oem spec exedy clutch. all good now
lopezchris21
25
Nov 19, 2023 08:24 PM
spidermancivic
19
Jun 24, 2005 10:30 PM
Hypertek99
Apr 1, 2005 12:02 PM
DRKSol
Mar 29, 2005 08:31 AM
turbotime
14
Oct 22, 2004 12:14 AM
