Ls Vtec ECU Question JDM or USDM p72
I am running Ls Vtec setup with a jdm p72 ob1 ecu is there an advantage with running with the usdm p72 or are they both about the same...of if anyone knows what;s the difference between the JDm and USDM P72 ecu from the 94-95..
They are almost the same thing...
I recommend you look into a modified ecu for your ls/vtec setup.
Check out https://honda-tech.com/zerothread?id=1232187
Luserkid
Nov 27, 2003 04:02 PM
