Difference between USDM & JDM ECUs???
Old Jul 18, 2005 | 09:54 AM
AreJay126's Avatar
Default Difference between USDM & JDM ECUs???
Hey i recently bought a manual obd1 p72 not knowing that it was JDM. Does anyone know if theres a difference between this ecu and a USDM one?
Old Jul 18, 2005 | 06:59 PM
AreJay126's Avatar
Default Re: Difference between USDM & JDM ECUs??? (BBoyRJ2000)
bump
Old Jul 19, 2005 | 06:22 AM
AreJay126's Avatar
any1?
Old Jul 19, 2005 | 05:19 PM
AreJay126's Avatar
no1 knows the answer 2 this?
Old Jul 19, 2005 | 05:22 PM
jennifermike's Avatar
nothing really i think
Old Jul 19, 2005 | 05:24 PM
RHDintegXsi's Avatar
Default Re: Difference between USDM & JDM ECUs??? (jennifermike)
the jdm ecu's havea speed gov. at like 110 or so.. you can go to the dealership and havethem look up the serial number to see if its usdm..many times when you go to get your swap ref'ed they will require proof that your ecu is usdm..dealerships can provide that
Old Jul 19, 2005 | 05:32 PM
AllMotorDan's Avatar
yeah i know the jdm ecu has a fuel cut off around 110-120 my friend had a jdm ecu but then got a skunk2 chipped ecu
Old Jul 19, 2005 | 09:24 PM
AreJay126's Avatar
Default Re: (SpoonSirG)
o ok thanks alot guys. whats the fuel cut off 4 a usdm p72?
Old Jul 21, 2005 | 07:35 AM
integra racr04's Avatar
no fuel shut off on USDM, but i couldnt get mine to go any faster then 135mph...
Old Jul 21, 2005 | 10:50 AM
SleepRdc2's Avatar
my jdm p72 has a vtec engagement around 4300 under 1/2 throttle, and around 5000 under 1/4 throttle.
Old Jul 21, 2005 | 01:53 PM
mugenracer's Avatar
Default Re: (SleepRdc2)
JDM P72 has VTEC cut in at 4400rpm and secondary butterflies at 5800rpm the exact same as USDM GSRs. VTEC needs certain criteria before it activates and engine load is one of them, so you can drive at 100mph in 5th gear on the level and because there is no load on the engine and the VTEC wont be activated. This is the same for USDM integras as well as JDM. JDM ECUs (P72) have a smaller body, theyre 3/4 the size of a USDM p72 ECU, i dont know how a US GSR will run on one as they're set up for a higher ocatne fuel, higher CR (10:6:1) and will have slightly more aggressive air/fuel and ignition maps, but they should work ok in a US GSR, except for the 190kmph (119mph) speed limiter.
Old Jul 21, 2005 | 05:25 PM
AreJay126's Avatar
Default Re: (mugenracer)
thanks alot man
NaCk3m
Sep 7, 2006 05:52 PM
EK FLY
May 24, 2005 10:17 PM
prelude9999
Feb 22, 2005 10:49 PM
BLK99VTECR
Jul 2, 2004 09:34 PM
