Help quick! Removing ball joint. w/pic
Old Jun 15, 2005 | 02:16 PM
copperfox's Avatar
Default Help quick! Removing ball joint. w/pic
Here is where I am at:
How do I remove the ball joint? It hits the area right above it!!
Old Jun 15, 2005 | 02:28 PM
copperfox's Avatar
Default Re: Help quick! Removing ball joint. w/pic (copperfox)
NEVERMIND@@@@!!!!!
haha sorry.
It appears that the ring it hits comes right off....
How do you do that little hammer-hitting-head icon?
<insert that here>
Old Jun 16, 2005 | 12:53 AM
kidkombo's Avatar
<< like that?
Old Jul 8, 2005 | 08:21 PM
copperfox's Avatar
yeah, that's it!
Old Jul 13, 2005 | 05:39 PM
SoOHiGH's Avatar
Default Re: (copperfox)
hey how did you remove the ball joint in the first place?
im not sure how to take mines off and i dont want to damage the boot.
Old Jul 13, 2005 | 05:54 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: (SoOHiGH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoOHiGH &raquo;</TD></TR><TR><TD CLASS="quote">hey how did you remove the ball joint in the first place?
im not sure how to take mines off and i dont want to damage the boot.</TD></TR></TABLE>
bump i wanna know too, I paid 20 each side to get mine done a while back when i got my integra brake swap, and I have a feeling i got raped
Old Jul 13, 2005 | 06:15 PM
eric416's Avatar
u need a ball joint tool and u bang the crap out of it till it pops out. U can pick one up for like 10 bucks at a pepboys.
Old Jul 13, 2005 | 06:19 PM
Aespooncivic's Avatar
Default Re: (eric416)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by copperfox &raquo;</TD></TR><TR><TD CLASS="quote">NEVERMIND@@@@!!!!!
haha sorry.
&lt;insert that here&gt;
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eric416 &raquo;</TD></TR><TR><TD CLASS="quote">
u need a ball joint tool and u bang the crap out of it till it pops out. U can pick one up for like 10 bucks at a pepboys.</TD></TR></TABLE>
Old Jul 13, 2005 | 06:34 PM
rasinhell's Avatar
Default Re: (Aespooncivic)
You dont need any special ball joint remover tool. Those dont work very good. The easiest way to do it is by removing the snap ring w/ a snap ring remover (you can buy these for 1.50 at harbor freight). And then you remove that ring piece that the guy is referring to w/ a flathead. making sure the tie rod is disconnnected, you can pull the hub upward to get a better angle and hammer the **** out of the ball joint until it slowly creeps out. Installation is reverse.
Old Jul 13, 2005 | 07:00 PM
SoOHiGH's Avatar
Default Re: (Plugg'd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Plugg’d &raquo;</TD></TR><TR><TD CLASS="quote">You dont need any special ball joint remover tool. Those dont work very good. The easiest way to do it is by removing the snap ring w/ a snap ring remover (you can buy these for 1.50 at harbor freight). And then you remove that ring piece that the guy is referring to w/ a flathead. making sure the tie rod is disconnnected, you can pull the hub upward to get a better angle and hammer the **** out of the ball joint until it slowly creeps out. Installation is reverse. </TD></TR></TABLE>
the only thing i saw is this
http://www.harborfreight.com/c...=3316
is that it?
Old Jul 13, 2005 | 07:31 PM
B18EG6's Avatar
is that it?</TD></TR></TABLE>
thats a snap ring tool yeh
th eonly thing holding that balljoint in there is a snap ring, thats it?
Old Jul 13, 2005 | 08:37 PM
rasinhell's Avatar
Default Re: (B18EG6)
Yeah. But even after the snap ring is out, it does take a bit of a beating in order for it to pop out of the little spot. I just dont understand why some people take their entire knuckles to shops and have them do it, when they just do the same thing =P...
Anyways. Speaking of ball joints. I need a ball joint because I mushroomed my other one. Does anyone know a site to buy them cheap? The autozone in my area sells them for 29 bucks! TWENTY NINE BUCKS?!!? ********..
Old Jul 13, 2005 | 10:20 PM
dcsports's Avatar
hammer it out that what i did no need for a tool ohh i sprayed alil pb blast on it also
Old Jul 13, 2005 | 11:31 PM
midwesta's Avatar
you guys are all over the place
you need a ball joint popper tool also called a PICKLE FORK or to remove the LCA to get to THAT POINT, and u gotta hammer the **** out of it but be careful not to rip the boot. which is hard to do.
Old Jul 13, 2005 | 11:34 PM
rasinhell's Avatar
Default Re: (techintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by techintegra &raquo;</TD></TR><TR><TD CLASS="quote">you guys are all over the place
you need a ball joint popper tool also called a PICKLE FORK or to remove the LCA to get to THAT POINT, and u gotta hammer the **** out of it but be careful not to rip the boot. which is hard to do.</TD></TR></TABLE>
I think most of us were assuming you already have the knuckle in a position to where the ball joint can be hammered out. You can't just remove the knuckle form the lca and then hammer the ball joint out because w/o taking the snap ring out, you're not going to get anywhere. You dont have to be careful when hammering the **** out of it at all. Who cares if you rip the boot when you're replacing it anyways? It's gonna go in the trash.
Old Jul 19, 2005 | 02:31 PM
SoOHiGH's Avatar
i hammered the F#$@% out of my ball joint but it still wont come out
Old Jul 19, 2005 | 02:45 PM
JustinL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Plugg’d &raquo;</TD></TR><TR><TD CLASS="quote">Anyways. Speaking of ball joints. I need a ball joint because I mushroomed my other one. Does anyone know a site to buy them cheap? The autozone in my area sells them for 29 bucks! TWENTY NINE BUCKS?!!? ********..</TD></TR></TABLE>
i bought 2 at NAPA for like 25 bucks total. i only go to napa though....
Old Jul 19, 2005 | 02:52 PM
JDM-97CX's Avatar
Default Re: (pyro_assassin)
I use my handy dandy air hammer and pickle fork attatchment. I finished both of my ball joints in about 45 minutes.
Old Jul 19, 2005 | 02:57 PM
CardDealer's Avatar
Banned
Modified by CardDealer at 4:49 PM 11/16/2006
Old Jul 19, 2005 | 09:52 PM
rasinhell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pyro_assassin &raquo;</TD></TR><TR><TD CLASS="quote">i bought 2 at NAPA for like 25 bucks total. i only go to napa though....</TD></TR></TABLE>
JEEZE perfect timing. I just got 2 off ebay for 40
ZOMBIEKILLER
Suspension & Brakes
11
Feb 24, 2008 05:51 PM
Silent_Destruct
Jan 23, 2007 12:08 PM
JohnWayne
Jun 15, 2006 11:08 PM
EG2Driver
Jun 6, 2006 08:50 PM
rasinhell
32
Jan 17, 2005 04:57 PM
