B16a2
Old Jun 15, 2005 | 10:45 AM
kbourque's Avatar
Default B16a2 Tick
Hey guys, i just had my valves adjusted by Honda and I was just wondering if it is normal to hear any sort of tick from inside the car. It's not loud, but it is a little annoying sometimes. Or is this the normal Honda tick?
All fluids checked
150000kms
1999 Civic SiR
Old Jun 15, 2005 | 10:50 AM
crxtreme89h's Avatar
Default Re: B16a2 (kbourque)
Was the tick there before? I notice a slight tick from my B16a as well.
Old Jun 15, 2005 | 11:03 AM
kbourque's Avatar
Default Re: B16a2 (crxtreme89h)
When i first got the car i didn't notice it, probably 2 months after i had it was when i first heard it, but maybe i just didn't notice or had the music up louder before.
I just wanna know if it's something to worry about.
Old Jun 15, 2005 | 12:54 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: B16a2 Tick (kbourque)
could be the injectors, or a bad lma
Old Jun 15, 2005 | 12:56 PM
EL Vap133's Avatar
Default Re: B16a2 Tick (PURPLETERROR)
My guess are the LMAs too.
Old Jun 15, 2005 | 01:07 PM
aeonsi's Avatar
Default Re: B16a2 Tick (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">My guess are the LMAs too. </TD></TR></TABLE>
LMA? please unobreviate. I have the same deal.
Old Jun 15, 2005 | 02:33 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: B16a2 Tick (aeonsi)
LMA lost motion assembly
Old Jun 15, 2005 | 02:38 PM
FalkenSiR's Avatar
Default Re: B16a2 Tick (mar778c)
Yes, OBD0 injectors are loud, but loud enough to be heard from inside the cabin
And the typical honda tick is probably from the engines being raced too much imo
Old Jun 16, 2005 | 02:59 AM
kbourque's Avatar
Default Re: B16a2 Tick (fast88std)
Are LMAs or Injectors something that should be changed if they begin to tick?
Old Jun 16, 2005 | 04:25 AM
g2tegsown's Avatar
I have a JDM B16a and it ticks around the injectors for sure, but also I notice a tick that sounds clearly from the head. I've heard that somtimes they need valve adjustments to correct it. If I were to buy new valves, springs, and retainers would that fix clicking/ticking problem? (Providing the valve adjustment didn't fix it)
Old Jun 16, 2005 | 06:38 AM
tallguy's Avatar
Default Re: (g2tegsown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2tegsown &raquo;</TD></TR><TR><TD CLASS="quote">I have a JDM B16a and it ticks around the injectors for sure, but also I notice a tick that sounds clearly from the head. I've heard that somtimes they need valve adjustments to correct it. If I were to buy new valves, springs, and retainers would that fix clicking/ticking problem? (Providing the valve adjustment didn't fix it)</TD></TR></TABLE>
Id like to know as well.
Old Jun 16, 2005 | 08:27 AM
InJ3cted's Avatar
buy some prelude lma's, cheaper than the itr's. My jdm b16a did tick a lot and when i checked my lmas some of them stuck. I guess they wear out 15 years later. If you do a valve lash and make sure its not ur injectors or both then its your lma's most likely.
Old Jun 16, 2005 | 10:04 AM
kbourque's Avatar
Default Re: (InJ3cted)
My b16a2 is only 6 years old, still think it's the LMAs?
Old Jun 16, 2005 | 10:39 AM
g2tegsown's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InJ3cted &raquo;</TD></TR><TR><TD CLASS="quote">
buy some prelude lma's, cheaper than the itr's. My jdm b16a did tick a lot and when i checked my lmas some of them stuck. I guess they wear out 15 years later. If you do a valve lash and make sure its not ur injectors or both then its your lma's most likely.</TD></TR></TABLE>
Ok I have a couple of questions:
•How do I check my LMAs
•What is valve lash? Why would my injectors have anything to do with valve lash?
•I have never seen LMAs for sale, or anywhere (until this thread I never heard of them before), any idea where I might be able to find some? (Please don't say ebay)
Thanks for your help
Old Jun 16, 2005 | 12:07 PM
InJ3cted's Avatar
https://honda-tech.com/zerothread?id=157546 :check
http://www.team-integra.net/se...D=485 : valve lash for b16: .007 intake, .008 exhaust.
https://honda-tech.com/zerothread?id=566420 : prelude lma
Old Jun 17, 2005 | 04:41 AM
g2tegsown's Avatar
Thanks so much InJ3cted, looks like I got some reading ahead of me
I did do a little reading already, so the ITR LMAs will work without need of modification?
Old Jun 17, 2005 | 08:12 AM
InJ3cted's Avatar
yeah it will work but it will cost a lot more.
JDMfan77
11
Jun 17, 2010 08:24 PM
philosofy1
14
Mar 22, 2007 09:04 AM
drowzysleeper
Feb 19, 2005 10:35 AM
TylerC
Oct 1, 2004 05:57 PM
slooogsr
11
Jun 16, 2003 12:40 PM
