are honda valves just noisy?
this weekend i went ahead and did a valve adjustment. the car runs alot better i must say, but there is still some type of valve tapping. i thought when an adjustment was done it gets rid of this?
when i'm around 3K i can still hear the vavles tap. is it just me? or are honda engines (especially DOHC) like this? do i need to re-adjust?
Re: (allricedout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">yeah.</TD></TR></TABLE>
yeah?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">is it just me? or are honda engines (especially DOHC) like this? do i need to re-adjust?</TD></TR></TABLE>
which one?
yeah?
which one?
Re: are honda valves just noisy? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">Are you sure that what you're hearing is valve noise and not the injectors (which are quite loud)?</TD></TR></TABLE>
the engine is a B16A, i know the injectors are loud because when i shut the car off they're the las thing i hear, but i didn't know they can make a tapping noise? can they?
like i said, around 3K (like when i'm idled in 3K)it's alittle noisy. after 3K it's quite quiet.
Re: (jeffsciv23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffsciv23 »</TD></TR><TR><TD CLASS="quote">maybe you need oil? lol</TD></TR></TABLE>
just did a oil changeon sunday, along with the adjustment!
thanks though
thanks though
Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">yeah?
which one?</TD></TR></TABLE>
sometimes the valve spring retainers wear down and get burnt but it wouldnt make that much of a difference.
when i had my GSR engine my valves made the same ticking sound.... i adjusted the valves like 3 times but after i talked to a few sources, they said it was perfectly normal, and nothing to worry about.
Re: (allricedout)
when i had my GSR engine my valves made the same ticking sound.... i adjusted the valves like 3 times but after i talked to a few sources, they said it was perfectly normal, and nothing to worry about.</TD></TR></TABLE>
cool!
thanks fellas
cool!
thanks fellas
Agreed....listen to the injectors....unless you didn't use the correct feeler gauges when you did your Valve adjustment.
Darth ModerVader
Re: are honda valves just noisy? (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">the engine is a B16A, i know the injectors are loud because when i shut the car off they're the las thing i hear, but i didn't know they can make a tapping noise? can they?</TD></TR></TABLE>
Well, it's more of a "ticking" rather than a "tapping", but people often mistake injector noise for valve noise. It should, however, be relatively constant, not isolated around 3,000 RPM.
Re: are honda valves just noisy? (onesikdb8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onesikdb8 »</TD></TR><TR><TD CLASS="quote">
Agreed....listen to the injectors....unless you didn't use the correct feeler gauges when you did your Valve adjustment.</TD></TR></TABLE>
intake .006
exhaust .007
Well, it's more of a "ticking" rather than a "tapping", but people often mistake injector noise for valve noise. It should, however, be relatively constant, not isolated around 3,000 RPM. </TD></TR></TABLE>
it could very well be the injectors, but i notice it more around 3K since that's the rpm i usually cruise at (50-55MPH).
intake .006
exhaust .007
my car is the master of ticking
valves, injectors, LMA's
still runs great tho
i dont worry about it, i know the valves are in spec.
